Daikin Altherma ASHP technical specs
Hi,
I'm considering replacing my aging combi-boiler with an ASHP.
I've talked to 2 installers, one suggested a Vaillant Arotherm 12kW, the other a Daikin ("Daikin Altherma 3 H HT High Capacity Heat Pump (14-18 Class)"). These are both pretty big heat pumps, but the house is not very well insulated so has quite a high heat loss (we had a calculation done - and reducing heat loss is on the the to do list, but the existing boiler is nearing end of life, so I'm keen to replace it ASAP...)
Vaillant have a handy sheet with tech specs that shows the central heating output at different flow and external temperatures (e.g. the one I've been recommended suggests it can output 12.9kW at -3C with a central heating flow temperature of 45C). I'm assuming of course that these are approximations only.
My thinking was that I can compare these numbers to the actual energy usage of my house with the current set up (which I can estimate from gas usage) and see if the heat pump is roughly able to meet my requirements.
Does anyone know if Daikin has a similar data sheet somewhere? I've search around but can't find anything
thanks in advance!
Welcome to the forums @bm212. I reached out to Daikin this morning, and they'll send across the docs to me tomorrow and I'll post them here for your reference. Where in the UK are you based?
@bm212 you’re welcome. Let us know whether you go down the Vaillant or Daikin route.
Posted by: @bm212Hi,
thanks in advance!
Might it be worth considering the size of heat pump required AFTER you have made the improvements to the property? As we are now heading into milder weather, perhaps the urgency to replace the aging gas boiler may be slightly less of a ‘distress’ factor.
If the insulation you intend to fit is sufficient to take the heat requirement down a notch, you might be able to use a smaller heat pump. If the insulation were not finished by next winter, you could use some supplementary heating pro tem; this might still be better long term as the smaller better matched heat pump should perform more efficiently for years to come. Regards, Toodles.
@toodles that is a logical approach. However, I'm going to need hot water, even in the summer, and I'm not sure I have a feasible short term alternative in the event that the boiler fails suddenly and I am left without a replacement for however long it takes until I can organise a heat pump installation.
I've had a heat loss survey done, and have done some calculations based on that. I also did my best to validate the calculations with experiments. Together this suggests that even with all the energy efficiency improvements that are practical to carry out (external wall insulation, replacing the remaining single glazed windows with double glazing, replacement of some of the radiators to account for the lower flow temperature coming from a heat pump rather than a boiler), I'll probably still need a similarly sized heat pump.
(These types of calculations are ultimately only estimates, and my ability to measure heat loss of the house was limited by the mild weather over the winter, but sadly this is the best information I've got at this point)
one issue you need to consider along with the radiator resize issue is the pipework size itself. i assume you have also looked at where you have space to accommodate your (new) hot water cylinder/heat store etc?
i think going down the insulation route first is a sensible option as you may be able to do a lot of that yourself, you could even fit your own new double/triple glazed windows, it isnt difficult, and get them signed off by building control. That will also save you a considerable amount of money. If you have a company who manufactures (or more likely has them manufactured for them) who would come out and measure etc, then the savings can be considerable, depending on how old your windows are and what style, then you might not even disturb any internal plastering/decorating (or just need a strip of upvc to cover any minor damage. Old style sash windows are a bit more difficult, but not complicated, they just need a bit more internal work after installation.
@misterb I can't really say too much about the pipework - except that what I see coming out of the floor going into the radiators looks like standard 12mm (ie not microbore). The rest of it is buried under the floor, and I don't really fancy taking that up to find out what's going on (there's a hardwood floor in much of the house, and I don't want to break it). It would be great if there was a non-destructive way of figuring out what the pipe sizes are...
I've got space to accommodate a cylinder so that should be ok I think.
Agree insulation and/or glazing is a good first option.
I'm definitely not going to be competent enough to fit my own windows, so that is a job I'll pay a professional to do!
A fair few of the windows are old and need replacing eventually anyway, so I'll happily do that first if the lifetime of the boiler permits.
If it's 15mm to the radiators then that's a positive!! As for the new cylinder, depending on layout/location, the cylinder might be better off in the loft as pipework can be run externally up the wall (well insulated of course)
I'm not expert and only know what I've read, so please don't take my comments as 'gospel', but I think it's well worth getting a few quotes to see if it's financially viable.
- 25 Online
By ThunderMink , 16 minutes ago
By Judith , 9 hours ago
DESNZ doing a survey which asks the right questions!
DESNZ have engaged ICF to do a survey of people who hav...
Just done your survey!
By Judith , 10 hours ago
By JamesPa , 10 hours ago
@grahamf you appear to value your recirculating loop de...
By Judith , 11 hours ago
By Tasos , 14 hours ago
By Mars , 15 hours ago
By Scalextrix , 2 days ago
Inventor (Midea) Heat Pump short cycling advice
Hello, I have a Inventor (Midea) 8kW with a 800meters Φ...
By immunity , 2 days ago
By bontwoody , 3 days ago
By Alex , 3 days ago
By GrahamF , 3 days ago
By DREI , 3 days ago
By Profzarkov , 3 days ago
