BUS Grant: removal of all other fossil fuel heat sources
@rikiarn - just have a think as to how much it will cost you to keep that gas fire available as a backup heat source.
We don't know whether you use gas or electricity for cooking,
but the ongoing Daily Standing Charge is likely to take up a sizeable chunk of your annual gas bill once your heat-pump is operational!
- 73 Online
Yes. They cost about £400 to buy or you might be able ...
By JamesPa , 19 minutes ago
If that's the case then you are right to be sceptical, ...
By JamesPa , 31 minutes ago
Havenwise App Help & Forum Support – Get the Most from Your Heat Pump
We’re pleased to announce that Havenwise are now joinin...
By Mars , 2 hours ago
By Lucia , 3 hours ago
By JamesPa , 4 hours ago
By jamespetts , 13 hours ago
By ASHP-BOBBA , 14 hours ago
By JamesPa , 15 hours ago
By Tim441 , 19 hours ago
By Transparent , 20 hours ago
By HCas , 23 hours ago
By jamespetts , 23 hours ago
By jamespetts , 24 hours ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 3 days ago
