Balancing financial efficiency and comfort using the Octopus Cosy tariff
@webcmg That crystal ball I mentioned…, well hindsight is wonderful, but who has foresight? I had solar and battery installed in August 2022 - look what has happened to energy prices since then! Rather than ‘payback’ I prefer to think in terms buying my energy as cheaply as I can ATM but, having the security of supply as of great importance too. @old-scientist is enjoying his fling with IOF just now and that looks like a good prospect to improve ‘payback’ too. Regards, Toodles.
Posted by: @webcmgI do need to track what the peak usage is outside of Cosy slots in order to determine what the smallest battery I could get away with is... that would reduce the investment cost and minimise the breakeven period. I think I will need to contact OVO to get an annual hourly usage breakdown...
I estimated our usage on the following basis.
The most challenging 6h window for us is 4-10pm as it coincides with cooking/meal time (electric oven, air fryer, microwave, kettle all potentially in use) and no solar generation to help out.
I estimate our heat pump runs at around 1.2-1.5kWh input, so heating for the 6h may require somewhere between 7-9kWh. Background use is another 2-300w (~1.5kWh). Then we may want the electric oven on to cook using another 2kWh?? (I know it draws 2.7kW don't really have a firm number on average usage per hour as it kicks in and out). So our 13.5kWh Tesla Powerwall seems ideally sized for us to meet our peak demand in that 4-10pm window. We could reduce the demand slightly by overheating the house by 1C in the run up to 4pm, and then knocking the flow temp back slightly if we know we are going to be cooking a large roast dinner and battery capacity is going to be tight. The house should not cool noticeably with the heating still on low and the additional heat output from cooking.
Laws of diminishing returns. It may be the case that a battery large enough to cover your usage on 80-90% of days is good enough, and doubling it's size for those last 10% of days makes less economic sense. If batteries were only available in 5kWh modules, we'd need 15kWh, but 10kWh would do most of the time and that's what I would go for. The Tesla PW3 at 13.5 kWh just so happened to hit our sweet spot.
We’re high energy users other than the ashp so the OVO tariff wouldn’t work for us, so cosy was the next best. We averaged 17p per kWh using a 9.5kWh battery to get our 7kW ashp through peak hours. I did calculate the financial payback for a bigger/additional battery but it was just not viable. Too small a saving.
- 2,153 Topics
- 47.3 K Posts
- 36 Online
- 5,673 Members
@tim441 Puts even more reason behind any proposal to ha...
By Toodles , 3 hours ago
By JamesPa , 4 hours ago
By bontwoody , 21 hours ago
By Alex , 22 hours ago
By GrahamF , 22 hours ago
By Morgan , 22 hours ago
By DREI , 1 day ago
By Profzarkov , 1 day ago
By GrahamF , 1 day ago
By cathodeRay , 1 day ago
By ASHP-BOBBA , 2 days ago
By DREI , 3 days ago
