ASHP in Spain – What should I do?
Hello everyone,
Considering installing ashp in my villa which is in Costa Blanc Spain.
At the moment I have a gas combi boiler on LPG which costs a fortune to run my ufh, LPG is not cheap in Spain at 2.30 euros a kilo. I have solar panels giving 4.5Kw peak on most day's of the year. Looking at ashp to run ufh only with a 200l buffer tank with mixing valve to top up heating when not generating power from solar. Pump would only run approx 4 months of the year, excess solar would be used for cooling in summer. Looking at 12Kw heat pump to heat 210sqm living space I have cavity walls and insulated loft space, winter temperatures very rarely go below +5c and with ufh I only loose 2 degrees overnight.
First question, would this type of system warrant the initial outlay. LPG used last year cost approx 2200€ and is going up in price daily.
Second question. I have enough knowledge of central heating installations (the basic plumbing)that I would like to attempt a DIY install, problem is system design, any help appreciated.
That's it for now, willing to answer any questions that are required.
Welcome to the forums @keithc.
Do you already have a wet CH system installed?
An option here, if possible, would be go with an air-to-air heat pump (as opposed to air to water) that would heat in the winter and cool in the summer using your solar PV?
As far as DIYing the system is concerned, with the right amount of research relating to unit you opt for, that is very possible and we've been in touch with many DIY installations that have been a success.
At 2.3 euro/litre, 7kWh per litre for LPG and 2200 euro per year I make that roughly 6700kWh. Assuming you get a COP of 3 then your ASHP would consume 2200kWh or so to deliver that much energy. Even if that were all in a 4 month window that's less than 20 kWh per day or less than 1kW.
It's a bit more complicated than that but you get the idea. BTW my ASHP rarely if ever uses more than 3kW (UK).
I'm not sure about using the same unit to cool. As Mars says you could have A2A units for that.
UPDATE
Heat pump now installed Kosner MD12 monobloc. Turns out to be a Milea M Thermal. 10 year warranty clinched the deal.
Installed with 60ltr water transfer tank, no circuit water ever enters the unit.
Have changed some weather compensation setting as follows:
@ 2c outside floor temp should be 38c
@ 22c outside floor temp should be 33c
Room temp 24c
These settings are to force the unit to run during daytime when I am generating solar power. My installer considers me to be crazy, but I have a warm house that is only losing 2 degrees overnight and costing pennies to run. We are now entering wintertime here with freezing temperatures of 12c overnight lol.
Anyone see anything wrong with what I've done please let me know as always open to suggestions.
2 days ago
2 days ago
Where has Watson gone?
2 days ago
First time wall mounting an ASHP
2 months ago
2 months ago
- 2,396 Topics
- 54.3 K Posts
- 179 Online
- 6,077 Members
@simonf I’ll ask the installers to get them out. What k...
By AdamK , 7 hours ago
Thanks for all the help/comments. I completely agree w...
By JamesPa , 9 hours ago
I doubt that matters, ToU tariffs are for the benefit o...
By JamesPa , 14 hours ago
RE: Free Ecoheat Heat Pump Install
@deltona Yes older houses are problematic like that, bu...
By bontwoody , 17 hours ago
As I mentioned early on the cost of supplying and fitti...
By JamesPa , 20 hours ago
I hadn't spotted that there were two pumps in the UFH (...
By JamesPa , 21 hours ago
Never assume it makes an ass of u and me! You need the...
By JamesPa , 22 hours ago
Before I answer your specific questions just one more t...
Great point, one of the key ones in my chat with Octopu...
Definitely and professionals sometimes miss it. I had...
Let me point out that there are many Chinese suppliers ...
@majordennisbloodnok — The Two Ronnies Mastermind sketc...
Just realised that this image of the cylinder cupboard ...
Two thoughts: 1: Let's ask @david-s if Primary Pro in...
In the diagram below, I describe my understanding of th...
I need to have a look out for it. I know IBM feeds some...
RE: Daikin Atherma ASHP Cycling 6 Times an Hour?
Thanks for your reply. Yes that's a good idea to try a...
By John Marshall , 2 days ago
RE: Hot water heating in parallel with space heating
An external heat exchanger would need a pump which woul...
By bontwoody , 2 days ago
RE: Gen 6 Samsung ASHP losing 20C of DHW in 60 min directly after generation
@ecobaker Thanks for this. I've had it in both slots. ...
By andbeck , 2 days ago
