Mitsubishi ecodan 1...
Mitsubishi ecodan 11kW ridiculously expensive running costs. Help!
4 Users
0 Reactions
(@parmstar)
The heat pump is a
PUZ-WM112VAA
controller is shown on the pic and it’s a 3rd party joule 300l cylinder
9C4AE3EE B3B0 4171 AABA 44AD4FE34941
(@hughf)
Is the controller in the hallway or in the cylinder cupboard?
and I’m asking for photos so I can map out the plumbing layout…. It saves me asking you ‘do you have a buffer, do you have a plate heat exchanger, do you have a llh, is your primary pump pwm controller’ etc…
(@parmstar)
Thanks Hugh- the cylinder is located in airing cupboard with the main controls and the thermostat is located in the hallway. The ASHP is on the side of the house with the flow and return pipes running up the side of the house in to the loft where the rest of the install is located. See pics. I hope that helps
33291957 075D 4838 AB97 B60088A80AA8
F7E08F4B EA9B 484D 8E8D DB736C792B9D
D2C7DBF4 EBD8 4C4E A83D E85F590B296A
E7147A5F A74C 4F86 94DE 03AFCE63434B
75B58F91 A456 4124 8846 12207C03F717
(@hughf)
79307B3E B835 4259 A0B0 F61E944F3577
How many cables go to this pump? It will either be one, or two.
With the ecodan controller located in the airing cupboard, your system is installed like a boiler, with the ecodan controller having no input on the flow temperature and the thermostat controlling the secondary pump.
Unless you have a Mitsubishi wireless thermostat in your hallway? What brand of thermostat do you have?
(@parmstar)
@hughf its a ecodan wireless remote controller and reciever - PAR-WT50R-E / PAR-WR51R-E
There is just one cable going to that pump
(@hughf)
Ok, so the primary pump is not pwm controlled so the heat pump isn’t able to modulate it’s flow. Not the end of the world but certainly not the most efficient way of doing things.
Are you running the ecodan controller in auto adaption mode or standard weather compensation?
(@parmstar)
@hughf standard weather compensation. I am just on the phone to Mitsubishi technical now and sent them a screen shot of my usage chart through my solar app. They are slightly concerned and he has gone to speak to his colleague..... got me even more worried now! Will post an update shortly. (Usage chart attached for your perusal)
IMG 1478
(@parmstar)
They said it's fine to cycle like that as its on the hour - he thought it was cycling a lot more. It was not until I zoomed in he confirmed that it is ok like that.
(@hughf)
Cycling looks fine to me, not too short. It’s bubbling along at 6.5kW ish, all night. Heat loss is very good for something that’s 400 square meters. We’re at 6.7kW heat loss at -3/21 and we’re only at 100 square meters.
(@batalto)
Given your house size, I'd personally whip out that low loss header as well. Cant see flow rates being an issue in 400m2 of floor space.
262m2 house in Hampshire
Posted by: @parmstar
IMG 1478
This is more likely to be defrosting.  (The term cycling is usually used where the ASHP can't modulate down low enough where the load is low) My Ecodan energy looks very similar at the moment and it's definitely defrosting every 60-80 minutes as I can see it on my monitoring.  All normal in these conditions.  You can see the flow plummet and a tiny blip in the ambient (assmued because of where the sensor is).
chart (1)
(@hughf)
Posted by: @batalto
Agreed, going direct would bring a benefit on efficiency. Can the ecodan drive a pwm primary pump? I haven’t checked the wiring diagrams .
Page 2 / 2
