Anyone taken a thermal image of their ASHP condenser unit?
No, it's R32. A split system so it's pumped from the outdoor unit up the outside wall to the indoor unit in the loft.
if you have witnessed a refrigerant leak then the system will need to be thoroughly checked. The joints are flared and should seat perfectly. If they don’t and it leaks you have a dead system.
These units a preloaded for a run of up to 15m (generally). So in a short run you might be ok in terms of refrigerant load.
however, and this is the important bit. If refrigerant got out, then it is highly likely that moisture and or air got in. These are non compressible and will cause a fault.
the best course of action is to have a proper fridge engineer come out and follow the service procedure to recover the refrigerant, fully nitrogen load and vac test the system. Then add the correct amount of refrigerant for the system. The preload amount should suffice unless it’s a long run.
the risk of not doing this are not just reduced COP but total compressor failure.
That banding is not a good thing.
Internationally recognised award winning installer of heat pumps and stuff
Ooh @seaenergy that's a bit worrying !!! I'll have another go at my installer then. Thanks very much for you advise. It's been running like that for over a year now - is it in trouble ?
I've sent an email to my installer to remind them that I asked about this at the service last April.
@heat-pump-newbie I would want it properly checked out. If there is a refrigerant leak it’s rarely a good thing. You could be very lucky and it’s all good.
The banding can happen for a number of reasons, the bottom coils for example sometimes use a base heater to heat them as that’s the part of the coils that gets the least heat recovery in defrost cycle.
I expect having it properly checked is cheaper than a new unit A lot of installers are not AC guys, when I do split units I bring in a specialist company to do the refrigerant pipework. They may need to get someone in to do the job properly.
- 311 Online
By AndrewJ , 20 seconds ago
i only know about Intelligent Octopus Go ToU, where acc...
By SKD , 41 minutes ago
By Bash , 1 hour ago
By benson , 2 hours ago
By trebor12345 , 2 hours ago
By RobS , 3 hours ago
By Batpred , 5 hours ago
By GC61 , 7 hours ago
By cathodeRay , 11 hours ago
By JamesPa , 21 hours ago
By Batpred , 23 hours ago
By DavidB , 1 day ago
By Slartibartfast , 1 day ago
