Any recommended ASHP in the South West?
Would anyone happen to have any recommendations for an ASHP installer in the South West (Newton Abbot area)? The property is an early 70's bungalow that will be brought up to (broadly, where it makes economic sense) Enerphit standards.
Have you searched on Heat Geek's website?
I wouldn’t discount installers further afield. Some are used to traveling, and it might be better if they stay in a pub one night which won’t be a massive addition to the bill.
Good installers are hard to come by in the South West.
By reputation I could suggest one based at Okehampton, and other in the Tamar Valley near Tavistock.
But you'll realise that there's a large slab of granite between those locations and Newton Abbot.
To gain the attention of either installer you'd have to be making a fair offer for a 2-hour round trip each day.
I suspect there's someone closer to you at Totnes or Torbay.
But you need to ask around for recommendations.
- 22 Forums
- 2,084 Topics
- 46 K Posts
- 30 Online
- 3,377 Members
RE: Surface mount or bury primaries?
@abernyte That is an excellent point. I hadn't consider...
By tomasmcguinness , 9 hours ago
It took me more than a few goes as well, plus some help...
By cathodeRay , 11 hours ago
By Mars , 22 hours ago
@jamespa I have a hydronic baseboard heater in the kitc...
By Scalextrix , 2 days ago
By Bart , 2 days ago
Here’s a little more technical detail/p>
By Judith , 3 days ago
By AF1 , 3 days ago
By Old_Scientist , 5 days ago
By JamesPa , 5 days ago
RE: Plate heat exchanger considerations
As far as I can tell my vented system would have a peak...
By Scalextrix , 6 days ago
RE: Air Changes per Hour - ACH and the MCS requirement
There have been a few discussions dotted around (e.g. I...
By Declan90 , 6 days ago
