alternative to Home...
alternative to Homely - HavenWise. Anyone used it?
11 Users
22 Reactions
(@broadsman)
@editor Thank you, and fingers crossed.
(@alfapat)
Posted by: @alfapat
It looks like I can fit Modbus to my Gen 5 Heat pump , I have been sent an instruction to change the installion on my Samsung Controller.
My question remains Homely or Havenwise
A query and a rEquest sent to Havenwise yesterday has not been answered yet , so I am going to ask if anyone on this forum who has Havenwise do I need Modbus board as well as Samsung WIFI . I now know that I can or someone can , fit a MODBUS MIM-B19N board to a GEN 5 HP
(@arundalep)
@alfapat you only need the Modbus interface for Homely. Havenwise works through the Samsung API so needs the WiFi interface (which Homely doesn’t).
Homely - Modbus Interface
Havenwise - WiFi Interface
I would add though, I have plenty of experience and understanding re Homely & Modbus but no experience with Havenwise or the Samsung API so it might be better for someone from Havenwise to reply before you decide.
Sunamp for hot water storage.
Insulation upgrades:
EPS cavity wall insulation.
(@arundalep)
@broadsman sorry I missed the is previous reply.
Havenwise wasn’t available when I fitted my heat pump and Homely had just launched. I wanted to try it. It is very good at what it does and our use case is very complex. In short there is no product available that does what I want so I did it myself.
We have a Samsung HTQ, Sunamp for hot water, solar, battery, EV charger and V2G (vehicle to grid), using Octopus Intelligent Go. It is all fully integrated with Home Assistant and has taken a lot of work but now works great.
(@alfapat)
@arundalep Many Thanks for your thoughts there, I will wait in that case . I have to say I am not going down the solar route or EV but still want a good cost worthy solution. Ill hang fire till then.
Query here required , you still need something to energise The Heat Pump so that WiFi connects to it surely .
This post was modified 6 months ago by Alfapat
(@arundalep)
Posted by: @alfapat
I’m not sure what you are asking, can you clarify the question?
The WiFi interface provides an internet gateway to the heat pump. You can then control your heat pump using the SmartThings app or grant access to third parties (like Havenwise) for them to control it remotely. The WiFi interface is always connected and enabled.
(@alfapat)
@arundalep I thought the Samsung  wifi needed some sort of hardware in the HP , so thinking that would be the Modbus card , but clearly not. How does it communicate with the Heat Pump, perhaps your not the person to ask there as you have Homely ?
Anyway I have enquired into getting this from Samsung, but its slow going!
(@majordennisbloodnok)
Noble Member Moderator
Posted by: @alfapat
Any heat pump needs some hardware to communicate. If you want it to communicate via wifi, it needs a wifi adapter. If you want it to communicate via modbus, it needs a modbus card.
Since controlling a heat pump using an app is a selling point, it's very common (but not universal) for either the wifi hardware to be built into the heat pump or for installers to include the wifi module within the quote and installation. Modbus is far less commonly used so it's much less common for a modbus interface to be provided as standard.
Homely controls the heat pump directly and so needs a modbus interface to attach its wires to. Havenwise controls the heat pump via the manufacturer's cloud-based interface so as long as the heat pump is talking with the manufacturer's systems then it'll receive Havenwise's instructions via exactly the same route as if you were making a change using an app on your phone.
(@arundalep)
@alfapat the Samsung WiFi interface communicates with the heat pump on their proprietary NASA network (F1 & F2) and is powered by V1 & V2.  You do not need anything else (everything comes in the kit).
 HCas
(@hcas)
Thank you @majordennisbloodnok and @arundalep  for answering the question. Spot on 🙂
@arundalep Nice setup btw you have!
Page 6 / 6
