[Sticky] Air source heat pump roll call – what heat pump brand and model do you have?
I've got a Mitsubishi Ecodan 6KW with a 170 litre slimline pre-plumbed unit with an FTC7.
Forum Handle: Odd_Lion
Manufacturer: Samsung
Model: Samsung Mono R290 12kW
Type: ASHP
Arrangement: Split, low temperature
Area of Country: London
Home Type: Semi-detached
Size: 143 sq m
Insulation Level: Insulated loft and under GF, Solid brick walls, 1896 build.
Heat Loss Calculation: 10.13kW
Type of Controller: 1 thermostat zone for whole house
Type of Control: Weather Compensation plus thermostat
System Type: Radiators throughout house (11 total, mostly triple Stelrads)
Total Output of Heat Emitters:
Buffer Tank or Low Loss Header: NA
Secondary Pumps: No
Solar PV System: Yes, 19 420W panels (13 on roof, 6 on south facing wall)
Power Diverter: No
Battery System: Yes, 16.8kWh Solax battery array
Samsung 12kW R290 Monobloc, 19 South-facing solar panels, 16.8kWh battery array in a 1898 Semi-detached (solid brick) house in South London
Type: ASHP
Size: 143 sq m
Secondary Pumps: No
Power Diverter: No
- 752 Online
Actually, it’s better for wooden furniture – or at leas...
By JamesPa , 6 hours ago
By Bash , 7 hours ago
By Batpred , 8 hours ago
By cathodeRay , 8 hours ago
By Batpred , 9 hours ago
@tasos the OAT is incorporated into the control logic. ...
By benson , 10 hours ago
By DavidB , 11 hours ago
By Batpred , 12 hours ago
By Slartibartfast , 12 hours ago
By JamesPa , 13 hours ago
By Batpred , 14 hours ago
By Papahuhu , 15 hours ago
By Bash , 16 hours ago
By Odd_Lion , 17 hours ago
By F1p , 1 day ago
By Toodles , 1 day ago
By cathodeRay , 1 day ago
By Transparent , 1 day ago
By RICHARDF5033 , 2 days ago
By Will H , 2 days ago
