Air source heat pump
@editorAhh!
- 2,364 Topics
- 53.6 K Posts
- 282 Online
- 6,029 Members
How long will your energy contract last?
Some heat pump tariffs don’t run as long as a heat pu...
By Toodles , 20 hours ago
@morgan They are unsupervised these days, can’t get the...
@kevh it's worth remembering that many lsvs only actual...
Exactly. We only need to compare conditions, to decide ...
I found because I have very low heat loss I can set bac...
By RadWhisperer , 2 days ago
RE: Need Help Optimising My Rushed ECO4 Install: 12kW Bosch Heat Pump
Welcome @mickamills We too have an oversized 12kW Sa...
RE: My Powerwall 3 Consumes 3-4 kWh/Day in Self-Consumption: Is This Normal?
@caron I can confirm that the power usage of the PW3 is...
RE: Speedcomfort radiator fans
Thats true, but having tried (and succeeded) in constru...
@bash brilliant, thanks for the feedback
By energy9165 , 3 days ago
RE: Heat Pump Heats the House… But It’s Not Cosy. Emitter Changes or System Tweak?
@alastair There I was, feeling grumpy, he said “Cheer u...
RE: Grant Aerona: Is there a setting to keep the 2-port valve open during pump blockade
Depends on OAT. Mine cycles at OAT>10 and of course...
@transparent My conclusion is as you have noted, tha...
By Bash , 3 days ago
RE: Mitsubishi Ecodan R290 10kW performance
And to you too. Wishing you a very enjoyable festive s...
RE: External pipework insulation
They do? But that isn't apparent from the photos we'r...
@velcro welcome to the forums. Please feel free start a...
Daikin EDLA11D3V3 DHW Settings
I have a newly installed EDLA11D3V3 which I'm still get...
By Velcro , 4 days ago
@curlykatie did you get sorted with this?
By MickaMills , 4 days ago
RE: MyVaillant Connect Regular Disconnect
Thanks. Yes, if the time is consistently 11pm every nig...
By buckwem , 5 days ago
