5 Star Service from...
5 Star Service from Havenwise
10 Users
35 Reactions
 HCas
(@hcas)
@sheriff-fatman You're absolutely right that there is currently no solution on the market that orchestrates heat pump + battery + solar PV + EV together.
The 2 modes within Havenwise that I described earlier provide a good intermediate solution, but we won't stop there and further integrations are on the roadmap!
Posted by: @sheriff-fatman
Is the Havenwise solution capable of identifying when the heat pump will be running from stored battery power, rather than the grid, during the peak hours, as the effective cost of generation of these is different at any point in time?
Ah... I can see the problem you're identifying.
You could first check how big the issue is by temporarily putting some cheap (Chinese) energy monitors onto the grid connections to your battery-inverter and your heat-pump.
Here's a typical 2-channel energy meter on Amazon.
You can buy a lot cheaper via AliExpress, who also have a wider range of suitable products.
EnergyMeter2
However, may I turn the question around...?
What about running the heat-pump solely from the storage battery?
That reduces the complexity of the issue.
You then only need to decide when to recharge the battery from the grid.
This post was modified 4 months ago by Transparent
(@sheriff-fatman)
Posted by: @transparent
It's not a controllable option in the winter months with our current battery storage.  At some point in the day, the battery charge will be exhausted, and the heat pump will make the timing of that more variable.
It's not an issue in the summer months currently, and I doubt that the additional heat pump usage will impact that.
Longer-term the solution will be to add more battery capacity, which removes the issue, but we don't have that luxury yet.
To some extent...
... but the energy required by a heat pump is steady and predictable.
Your longer-term solution of adding more battery capacity is of greater interest to me.
Feel free to start a new Topic to discuss that.
Start by
  • giving us an overview of youir current inverter & battery arrangement
  • tag me so I receive an alert that you've posted this
  • a photo is useful
 HCas
(@hcas)
@sheriff-fatman Exactly this is why a lot of our users with a battery choose to do the following:
  • In the shoulder months: The battery and solar PV generation are sufficient to cover the household and heat pump consumption through the day. Havenwise "ignores" the tariff for heating and the heat pump draws from solar PV when the panels are generating, or the grid during cheap periods, or the battery outside of these periods. Result: all electricity consumption is coming from solar PV or from the grid during cheap moments, and the heat pump runs at maximum efficiency.
  • In winter: Obviously the heat demand is larger, and solar PV production is lower. So very often, the battery capacity is insufficient to supply the household and heat pump consumption through the day. So Havenwise shifts a part of the heat pump consumption to the cheap periods of the tariff, and the heat pump needs to consume less electricity outside of the cheap periods. Result: the battery capacity lasts longer through the day, and grid consumption for the house or the heat pump outside of the cheap periods is minimised.
This is just a switch for Havenwise. There is no need to adjust heat pump schedules or anything else for the user. And the user can choose when is the right time for them to switch between the 2 modes.
@sheriff-fatman : I know you already know this, so I'm describing this for the benefit of other readers.
Our interview with Henri from Havenwise it out:
3
Morgan
(@morgan)
@hcas and @editor
I have just watched the above video which makes me lean more and more toward going the Havenwise route.
I do wonder though, as with many new ideas/companies, how the future looks when the success and customer base becomes such that buyers come in to take the company off of your hands.  Say, for example, someone like BG Hive comes and offers a sum of money that you just can't refuse. Suddenly the wonderful hands-on customer service/response times offered by Havenwise go down the toilet. That's a concern that I have.  That said, I am more impressed with the system generally and will probably sign up before the coming winter. You answered one of my other concerns regarding Holiday Mode and being able to still have control of turning the CH off (as is the case here now) during the warm months.
Thank you for the video. Very enlightening.
This post was modified 2 months ago by Morgan
(@majordennisbloodnok)
Posted by: @morgan
@hcas and @editor
That's always a danger with any new good idea, @morgan. However, capitalism abhors a vacuum just as much as nature and so if a new owner either skimped significantly on customer service or (even worse, but still pretty common) ran the acquisition down so as to remove a competitor to their existing products then the door would be wide open for another actor to set up business with a similar model. That would likely result in either a new provider giving good service or the original solution being dusted off and being run properly again. Standard market competitive forces at work.
In some cases, a buyer isn't buying a product as much as the intellectual property behind it. In the case of Havenwise, there will certainly be proprietory algorithms but nothing that, if owned and patented, would preclude any other company coming up with their own way of achieving the same thing and competing. Buying out Havenwise wouldn't prevent a Havenwise lookalike from being developed and brought to the market by someone else.
To my mind, the real value of Havenwise is twofold; the plug-and-play simplicity of setting it up (appealing to the many non-techie homeowners) and the openness with which they do business (so the service's benefits can speak for themselves without obfuscation). Those are not expensive attributes for either the current owners or any future owner to keep going so I am optimistic for the foreseeable future. Obviously, as significantly more customers come on board Havenwise will have to rationalise a bit on response times and so forth but not necessarily to a detrimental point.
3
Page 3 / 3
