Would this count as Carbon Neutral?
As we are nearly a full year into having had our ASHP and having dispensed with gas completely, I’ll soon be able to tally up all our annual energy consumption. So far, it is looking as though we are using more than we can produce with our solar PV but, when our investment in ripple Energy’s Derril Water Solar Park starts to provide some energy payback, we might be ‘producing’ as much energy as we consume averaged over the entire year. We are using grid power via Octopus Energy during the colder darker months but will probably compensate for this consumption in our exported energy in the summer when the estimated kW/h’s from Derril Water are added to our PV. If these figures do add up - should I be able to claim that we are carbon neutral??? Regards, Toodles.
@toodles Ive been doing the same and hoping for the same result 🙂 This is my graph so far. The EV purchase last month has nudged it a bit the wrong way. Maybe I should get some ripple shares too!
@bontwoody Let me know if you need a Ripple referral won’t you! ;-))) Regards, Toodles.
@toodles Ah yes, of course!
never been quite sure about ripple and so far have avoided. As it is taxable income, its still just an investment to buy shares in a business. albeit one with a very ethical intent. For me, I'd rather do that in a more spread-risk manner using an ethically targeted market fund. whereas buy your own generation, income is tax free. If there was a tax change that made Ripple or similar exactly financially equivalent to investing in your own local generation then it would make a whole lot more sense.
- 332 Online
Registers 200 until 208 are read only according to the ...
By Mosibi , 22 minutes ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
@robs Do you need IAT for this to work? Don’t curren...
By Travellingwave , 53 minutes ago
@goodbyegas Hi Fellow Ecodan owner here. Looking a...
Having used ToU tariffs for a couple years now, I fear ...
By Old_Scientist , 2 hours ago
You can send private messages via the Messages (envelop...
By cathodeRay , 5 hours ago
With complete radio silence from Peak and no sign of th...
By DaveC , 5 hours ago
Yes, ours dropped by about 25% RH. I figured it was a c...
By Papahuhu , 6 hours ago
@batpred The Pace BMS also isn't the best with it's ...
By Bash , 7 hours ago
I understand now what you were referring to. This look...
By trebor12345 , 7 hours ago
@batpred I would consider changing your balance star...
By Bash , 8 hours ago
This illustrates what I am getting at, even apparent st...
By cathodeRay , 12 hours ago
No you arent, because you dont need any, and furthermor...
By JamesPa , 13 hours ago
As I mentioned earlier most radiators have a power outp...
By cathodeRay , 1 day ago
By DavidB , 2 days ago
By Slartibartfast , 2 days ago
By Bash , 2 days ago
By Odd_Lion , 2 days ago
