On the first Easter morning, Peter and John ran to the tomb, but it was already empty.
So that's two guys who forgot to put their clocks forward 😴
Recent advances in AI are stunning.
I enabled 'facial recognition' on my smartphone...
... and now it's suing me for emotional distress!
Raise your hand if you've spent a Sunday afternoon engrossed in your ASHP manuals and documentation, and if your family has a similar reaction:
We've seen some interesting comments about ASHP noise on the forums:
https://youtube.com/shorts/0kNCdwZK2ck
Witness the rise of a silent giant – the common heat pump! This nature mockumentary, narrated in a David Attenborough-esque style (not by him, naturally), delves into how this technology is phasing out fossil fuel boilers and underscores our responsibility to protect the planet.
@editor I see you have discovered the Greater Unspotted Heat Pump in its’ lair! Just feed it green energy and it won’t bite you!
Posted by: @editorWitness the rise of a silent giant – the common heat pump! This nature mockumentary, narrated in a David Attenborough-esque style (not by him, naturally), delves into how this technology is phasing out fossil fuel boilers and underscores our responsibility to protect the planet.
So can it be claimed that the heat pump is an 'invasive' species, that if not removed, or at least controlled, could lead to the extinction of the native fossil fuel boiler.
I would be careful about advertising the fact, otherwise you may have 'gas junkies' picketing your home and requesting a cull.
- 2,102 Topics
- 46.2 K Posts
- 111 Online
- 3,388 Members
PS to above. I just looked again at the photo you post...
By JamesPa , 6 minutes ago
And we have it: DESNZ are now investigating the feasi...
By Lucia , 2 hours ago
@skyefarmer great you located the source of the issue a...
By Mars , 5 hours ago
By ASHP-BOBBA , 15 hours ago
By Mars , 23 hours ago
By downfield , 3 days ago
By Sune , 3 days ago
