Came across a video I did last year in an attempt at being humorous.
Neighbour's Noisy Heat Pump
https://youtube.com/shorts/0kNCdwZK2ck?feature=share
@editor Never mind about the noise from that heat pump, do those birds not need planning permission? Very Antisocial of them!!!
@toodles they're a rowdy bunch!
Ah - how true @morgan
The path to Net Zero needs to be planned.
It's not enough to merely issue policy statements promoting on-shore wind-farms to be spread across the countryside...
... it's the execution which matters.
@transparent That’s the current concern.
From my perspective @toodles - this is the currant problem:
The spring sunshine is ripening the fruit early...
... but it's less than half the size it should be.
The berries have failed to swell due to lack of rain.
@transparent Not a swell season then ☹️
Apocalypse Then
So, yesterday evening I was watching BBC1 "Walking with Dinosaurs".
The 'experts' reckon their senses of smell and sight were well advanced.
Personally, I think they were deaf.
Their hearing had yet to evolve.
The production team flew the camera drone right above their heads, and no one of them looked up!
@editor Better still, set yourself up next to a data centre, (Listen to BBC Radio 4’s ‘Rare Earth’ broadcast at 12:04 [Data Centres and the Impact on the World] you could even heat that open-air swimming pool you have longed for! Toodles.
Posted by: @toodles@editor Better still, set yourself up next to a data centre, (Listen to BBC Radio 4’s ‘Rare Earth’ broadcast at 12:04 [Data Centres and the Impact on the World] you could even heat that open-air swimming pool you have longed for! Toodles.
…or next to Westminster and just recycle all the hot air generated.
- 2,104 Topics
- 46.3 K Posts
- 47 Online
- 3,393 Members
By rossowheels , 3 hours ago
@toodles Indeed. On a tariff such as IOF where import a...
By Lucia , 1 day ago
By Brendon Uys , 1 day ago
By Scalextrix , 1 day ago
By downfield , 4 days ago
By Sune , 5 days ago
