Posted by: @batalto@jeff that gas rate is more than my current peak rate for electricity... OUCH
If it is any consulation the gas vs electricity multiple is only 2.81 with these high rates making a stronger case for heat pumps if this turns out to be the new normal.
My fixed rate gas rate is currently 2.75p plus vat.
I’ve begrudgingly accepted the Eon fixed contract at 34p pkWh today. We’ll pay more from now until April from when the capped price should be similar. It will save us some money after the next hike in October when we consume the most electricity over winter heating the house.
Our projected cost for the year is now £11,900
Time to buy some more lottery tickets.
@George, I'm really annoyed because I forgot to sign up this weekend when the rate was 29p – today it's 34p.
Posted by: @georgeI’ve begrudgingly accepted the Eon fixed contract at 34p pkWh today. We’ll pay more from now until April from when the capped price should be similar. It will save us some money after the next hike in October when we consume the most electricity over winter heating the house.
I don't really know what to say to that. That's just astonishing.
@editor EDF 2 year fixed tariff has gone up again. Now 46.77p day, 22.25p night for electricity. Was "only" 33.39p and 20.20p on 23rd Feb.
Mike
@mike-patrick, it's frightening at how fast this is all shooting up. I don't keep tabs on mains gas at all, but is it going up at the same rate as electricity?
I am 100% getting more batteries this year. At these prices, they will pay for themselves in months vs years. You can get something like 5kw for £1,500 delivered. If I have 4kwh usable that's worth if you can fill them up every day
£146 @ 10p/kw
£292 @ 20p/kw
£438 @ 30p/kw
£584 @ 40p/kw
£730 @ 50p/kw
The value becomes even larger in the shoulder seasons or if you have some kind of time of use tariff you can arbitrage.
2 months ago
4 months ago
1 year ago
1 year ago
2 years ago
- 42 Online
@jamespa Thanks. Yes, its a bit sad so many of these jo...
By ASHP-BOBBA , 18 seconds ago
I managed to find a perfectly good new but 'last years ...
By cathodeRay , 7 minutes ago
By dgclimatecontrol , 2 hours ago
My heating isn't 'ON' yet, although it is firing up in ...
By Morgan , 2 hours ago
@damonc If the heat pump controller is in a suitable ar...
By HCas , 3 hours ago
If that's the case then you are right to be sceptical, ...
By JamesPa , 6 hours ago
By Lucia , 9 hours ago
By ASHP-BOBBA , 20 hours ago
By Tim441 , 1 day ago
By Transparent , 1 day ago
By HCas , 1 day ago
By jamespetts , 1 day ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 3 days ago
