Posted by: @transparentJust tell them that all Energy Smart Appliances (ESAs) should keep to a common clock system (probably defined by the Smart Meter).
I can believe that a car charger will be an ESA, but I don't think an actual car is. And I don't use the timing facilities in my charger, I use those in my car. So I'm not sure what I should be commenting on?
If you use the clock in the car to configure the charging times (as I do too) then that should fall within the comments which DESNZ obtain via this consultation. It might not be specifically mentioned in the Proposal Notes, but the answers we supply are free-form text. Just write it in!
They need to be aware that some of us the car's clock, and that this might be incorrect, particularly just after the clocks change twice per year.
Their proposals for DSR make too many assumptions about how us consumers actually behave.
If they really want to have all EV charging under the control of an Energy Supplier, then they'll have to create legislation which includes timing schedules set within a car. That won't occur to DESNZ unless we tell them.
Posted by: @bxmanYou can download your data and put it into excel with the appropriate hours and send it to your energy company and ask them to compare it with your invoice I think you will find they have no option but to accept the Half Hourly data.
My 39 message email chain with EDF would suggest otherwise!
(Although evidently I was awarded a settlement via the Ombudsman process. Albeit, to grant a settlement for what will continue to be an ongoing billing issue is only half a solution)
The simplest solution to both the overbilling problem, and the need to prevent numerous high consumption devices all switching on at the same time, would be for consumers to be informed of the randomised offset that has been applied within their electricity meter.
If the randomised offset is say 4 minutes and 11 seconds, and their ToU tariff runs from say 01:00 to 04:30, then armed with this knowledge they can merely set the switch on time to be 01:05 and the switch off time to be 04:34. Problem solved. 😎
I cannot think of any reason why each consumer being informed of their particular offset would pose any risk to the security of the electricity supply system.
@derek-m Frinstance, the Myenergi Eddi works to 15 minute increments - I don’t know if this works to tighter increments when twinned with a Zappi as I don’t have any such device. I suppose it would not be beyond the software writers to improve the resolution, but, would the average user be expected to religiously establish their particular offset and set timings accordingly? Regards, Toodles.
Posted by: @toodles@derek-m Frinstance, the Myenergi Eddi works to 15 minute increments - I don’t know if this works to tighter increments when twinned with a Zappi as I don’t have any such device. I suppose it would not be beyond the software writers to improve the resolution, but, would the average user be expected to religiously establish their particular offset and set timings accordingly? Regards, Toodles.
You are probably correct. "We are doomed".
If end-users make a mess of setting devices to turn on just after their Smart Meter crosses into the 'cheap rate' period, then that is itself a form of randomisation. 😉
It's still a lot better than what's currently happening with Suppliers starting our 'smart' chargers with minimal random offsets, and no appreciation of the local grid characteristics.
It does concern me, however, that DESNZ don't seem to appreciate how randomisation works or its effect on demand surges.
Their current proposals, around which the resilience of our future electricity supply is to be based, assume that more ESAs (Smart Devices) will be turned on/off or 'modulated' by receiving commands from a 3rd-party across the internet.
The data used to define when those control commands are sent will be national demand forecasts, irrespective of locally-available generation.
Moreover they envisage that the Independent System Operator & Planner (ISOP) will be supplied with those timings and will be responsible for ensuring that adequate electricity supplies are brought on-stream just ahead of when they're required. The DESNZ proposal is very much an example of "we control your stuff".
I don't think that's informed by an adequate view of how the Distribution Grid works.
I can see the data, and the weak points are at the 11Kv level and below.
That's where resilience is lacking.
The strategy to resolve excess current and thermal stresses at the local substations and their cables must be based on 'flattening the demand peak" in the early evening.
It has naff all to do with national demand.
I conclude that the design team who developed the Smart Meter specification around 2012-14 must've realised this.
They did know what they were doing,
and they put the randomised offset into the Smart Meters for good reason.
The current attempt to overrule that design feature by imposing centralised control of 'ESAs in the home' isn't based on good science.
From my experience with OE the problems have occurred when I have not been on a smart tariff . I believe that the H H is used regardless of offsets when on a smart tariff with OE.
I think the offsets control the time that the R1 & R2 delay their swap over .
On my E470 meter these are the default display on the meter screen showing as Rate 01 or Rate 02 and showing their respective totals depending on which one is operative at the time.
i can confirm that I can hear a relay switching at the time of changeover
I have not yet checked but I think my interactions with OE over this matter may exceed the
the 39
- 2,131 Topics
- 28 Online
- 5,655 Members
Thats true. Ideally the FT could go up a bit further i...
By JamesPa , 29 minutes ago
By JamesPa , 3 hours ago
By Tim441 , 22 hours ago
By Toodles , 22 hours ago
By Abernyte , 22 hours ago
By Eliuccio , 3 days ago
By Scalextrix , 3 days ago
By Scalextrix , 4 days ago
By Toodles , 5 days ago
By JamesPa , 7 days ago
By Judith , 1 week ago
By Old_Scientist , 1 week ago
By DavidAlgarve , 1 week ago
