Anyone still weathering it out with Agile?
@jamespetts I agree it's extremely hard to calculate ROI on batteries as it will also see changes in usage patterns as well as opening up tariff options.
Factors include
- EV? Usage? Charger?
- Solar panels? Size?
- Inverter charge/discharge rates?
- Batteries? Size?
- ASHP? size? Usage?
- Automation options including HA, WonderWatt Homely etc?
In my case
- EV? Yes Usage? Around 2000kWh/pa. Charger - zappi
- Solar panels yes Size 8.5kw
- Inverter charge/discharge rates? Only 2.6kWh
- Batteries? Size 24.6kWh
- ASHP yes size? 16kw Usage: 6000kWh/pa. Weather compensation controls
- Automation options including HA, WonderWatt Homely etc? Yes. WonderWatt
- I crank up heating of house and hot water at night on cheap rates
- Solar probably produces around 6500kWh/pa (not optimal orientation etc). Endeavour to export majority
Usage: say 6k ashp, 2k ev, 2k all other usage Inc lighting, cooking.
Import: say 3k kWh/pa at cheap rate overnight for later force export as well as filling batteries for own usage + charge ev + run ashp
Expected TOTAL imports 13000kWh @ 8p Intelligent Go = £1040
Expected TOTAL exports 6500kWh @ 15p = £975
Expected Net cost £65 for 1 year usage in 2025
So I conclude the batteries are a no brainer for me. But I could not have assumed that in advance. Charge/discharge rate is a significant barrier to maximising but newer installations are likely to be better especially if part of a setup such as Tesla, GivEnergy All-in-one etc
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
@tim441 As you say Tim, very difficult to quantify any savings or ROI even, for a battery; I have often wondered about the savings I make from my solar PV - the figures might be very different with or without a battery. Without a battery, I might quantify my solar ‘gain’ at 25 pence per kW/h as I would not likely be using a TOU tariff but a fixed one. As I do have a battery (Tesla 27kW/h Powerwall), I opted for Cosy and pay ~ 13 pence per kW/h and let the battery take the strain. But wait! I am only showing a solar ‘gain’ of ~13 pence per kW/h now!?😉. In fact, my exported energy realises 15 pence per kW/h with Octopus Outgoing Fixed (at the moment anyway!) Oh, now my brain hurts! Regards, Toodles.
@toodles I guess it all comes down to import averages. Which is going to be impacted by ToU tariff, time-shifting usage etc.
In my case I'm importing vast majority at night at 7p/kWh... for own usage and filling batteries.
In summer using batteries to force export + maximise solar export.
In winter using batteries to supply home ... and refill during day from solar (if any excess) + any bonus cheap slots.
I think I should keep the average for year sub 8p as a result. But with max exports it's a game changer.
When I was on Agile in 2024 the average was around 12 or 13p I think. But far less exports as the round trip was not worthwhile.
Tracker in 2023 was a decent saving vs fixed or standard contracts.
8kw pv solar
MG4 EV
We are still on agile and it works ok'ish to charge the EV. But the way the market is working I am not sure we will stick with it for long. We have HA but without PV I suspect our consumption will benefit from the predictability of a lower overnight rate.
- 416 Online
By Ubert767 , 31 minutes ago
By Renewables345 , 52 minutes ago
By JamesPa , 59 minutes ago
By Mars , 2 hours ago
By bobflux , 3 hours ago
By benson , 4 hours ago
By bobflux , 5 hours ago
By Jonatan , 10 hours ago
By Batpred , 18 hours ago
By Transparent , 21 hours ago
By bobflux , 22 hours ago
By Toodles , 1 day ago
