Unvented Hot Water cyclinder 300l 50c vs 60c
I have an 300l unvented cyclinder which I'm currently heating to 52c during cheap rate and then topping up at midday.
Probably 5 showers plus taps and kitchen sink usage.
My query is if I was to heat to 60c would that allow me to not have to top up in the day?
13.6kw Solar, 27kw Battery, 10kw Heat Pump and EV Car
It might do, try it and see?
As the majority of your usage is showering, where the hot water will be blended down to ~38C, heating it hotter should make it go further as less hot and more cold will be used for each shower.
On a practical note - can your heat pump actually heat the hot water to 60C? Mine can't, the flow temp cuts out at 60C max which achieves a DHW tank temp of ~54C. After this, the immersion kicks in, so hot hot you can heat will depend on the max flow temp your ASHP can achieve.
I will experiment, yes my ashp is capable of heating to 60c I'm sure I had it that way at the start.
- 2,149 Topics
- 47.1 K Posts
- 38 Online
- 5,667 Members
@diverted-energy hi. That sounds a good deal. We use ~8...
By JulianC , 13 minutes ago
I'm on Intelligent Go . Only since start of Feb. Before...
By Tim441 , 2 hours ago
@adamk apologies if my comments appeared thoughtless an...
By downfield , 4 hours ago
By GrahamF , 20 hours ago
By cathodeRay , 22 hours ago
I have heard of many people with a weakness for new car...
By cathodeRay , 1 day ago
By benson , 1 day ago
By Judith , 1 day ago
By TechnoGeek , 2 days ago
By Judith , 2 days ago
I’ve looked harder now (beyond OE’s site) and it’s not ...
By HCas , 4 days ago
By Old_Scientist , 4 days ago
By DavidAlgarve , 5 days ago
By SAEnergy , 5 days ago
By Temperature_Gradient , 6 days ago
