[Solved] Hot water issue, never seen this before: Grant Heat Pump and Cylinder
Hi all. A faulty mixer valve sounds like a likely cause to me too. Failing that there could potentially be some cross-flow going on; I notice on the photo of the combination pressure reducing valve, that the balanced cold outlet is plugged. Maybe there's a point in the system at which the higher-pressure cold supply is overpowering the reduced-pressure hot supply, travelling the wrong way down the hot draw off, and subsequently cooling the top of the cylinder down. A bit of a long shot, but this could be something to explore if a mixer valve issue is ruled out.
hi Tom, thank you and thanks to everyone else who replied.
it turned out to be a faulty shower that was causing the issue. This was closed off by a plumber and it fixed the issue straight away. Has now been replaced.
took 3 different plumbers to figure it out but we got there. Nothing to do with the pump or cylinder in the end.
- 22 Forums
- 2,086 Topics
- 46 K Posts
- 14 Online
- 3,377 Members
@tomasmcguinness bold choice on the Kronoterm. Nice! Wi...
By Mars , 6 hours ago
It took me more than a few goes as well, plus some help...
By cathodeRay , 22 hours ago
@jamespa I have a hydronic baseboard heater in the kitc...
By Scalextrix , 2 days ago
By Bart , 2 days ago
Here’s a little more technical detail/p>
By Judith , 3 days ago
By AF1 , 4 days ago
By Old_Scientist , 5 days ago
RE: Plate heat exchanger considerations
As far as I can tell my vented system would have a peak...
By Scalextrix , 6 days ago
RE: Air Changes per Hour - ACH and the MCS requirement
There have been a few discussions dotted around (e.g. I...
By Declan90 , 6 days ago
