Reusing existing radiators
We have received our system design from Aira, and as per the design there are about 9 radiator changes to meet the new DT22 requirements. I see that few of the larger K1 radiators that we currently have downstairs can be easily reused to meet the heat loss in the bedrooms. I know the four new K22 radiators are not pricey, but the whole purpose of us moving to heat pump is to reduce our carbon footprint. It would make sense to reuse the radiators where possible to avoid the perfectly working radiators going to landfill. The house is only 11 years old, so would have more life left in the radiators one would assume.
Does anyone have experience in reusing existing radiators for use elsewhere in the house as part of the heat pump installation? Your advice would be greatly appreciated.
16 * 435 watts PV
13 kWh Growatt battery
1 EV - Mercedes EQB
6 kW Aira Heat Pump
@chandykris Yes, I did that, just bought two big radiators and shifted the others into different rooms. No problems.
Thanks @bontwoody. I thought so too, but always reassuring to get my assumption validated from people who have first hand experience.
16 * 435 watts PV
1 EV - Mercedes EQB
6 kW Aira Heat Pump
@chandykris just give them a good wash out before fitting them back 😁
Boiling Mad: Exposing Radiatorgate
4 months ago
What is this white plastic ring on my radbots?
11 months ago
Homely vs TaDo for a heat pump. Does Homely only optimise twice per day?
2 years ago
Eskimo Column Radiator – Fronze Finish
2 years ago
Convector options for a small kitchen
3 years ago
- 2,396 Topics
- 54.3 K Posts
- 106 Online
- 6,077 Members
@simonf I’ll ask the installers to get them out. What k...
By AdamK , 2 hours ago
Thanks for all the help/comments. I completely agree w...
By JamesPa , 4 hours ago
I doubt that matters, ToU tariffs are for the benefit o...
By JamesPa , 9 hours ago
RE: Free Ecoheat Heat Pump Install
@deltona Yes older houses are problematic like that, bu...
By bontwoody , 12 hours ago
As I mentioned early on the cost of supplying and fitti...
By JamesPa , 15 hours ago
I hadn't spotted that there were two pumps in the UFH (...
By JamesPa , 17 hours ago
Never assume it makes an ass of u and me! You need the...
Before I answer your specific questions just one more t...
Great point, one of the key ones in my chat with Octopu...
Definitely and professionals sometimes miss it. I had...
Let me point out that there are many Chinese suppliers ...
By Transparent , 1 day ago
@majordennisbloodnok — The Two Ronnies Mastermind sketc...
By cathodeRay , 1 day ago
Just realised that this image of the cylinder cupboard ...
By Sheriff Fatman , 1 day ago
Two thoughts: 1: Let's ask @david-s if Primary Pro in...
In the diagram below, I describe my understanding of th...
I need to have a look out for it. I know IBM feeds some...
RE: Daikin Atherma ASHP Cycling 6 Times an Hour?
Thanks for your reply. Yes that's a good idea to try a...
By John Marshall , 2 days ago
RE: Hot water heating in parallel with space heating
An external heat exchanger would need a pump which woul...
By bontwoody , 2 days ago
RE: Gen 6 Samsung ASHP losing 20C of DHW in 60 min directly after generation
@ecobaker Thanks for this. I've had it in both slots. ...
By andbeck , 2 days ago
