Mitsubishi Advanced Auto Adaptation
Posted by: @slideruleAlso AAA does not follow a preset curve like WC. Presumably the "learning" is something to do with the observed rate of change of Room Temperature, but that's just guesswork on my part. Others have said it takes days to settle down after a restart to the system.
Please clarify.
Are you suggesting that a power-cut would lose the data which the AAA control system has 'learned'?
If so, then DESNZ need notifying.
They're proposing a Demand Side Response mechanism, which compensates householders who allow their heat-pumps to be turned off by a DSR-Agent using remote control.
Posted by: @slideruleI hope these experiences are of some help.
They are, and thank you for the detail of what you do. One of the many useful functions of this forum is that it provides a repository of different ways to tackling various setups.
I doubt we will ever know exactly how AAA or Homely for example work, that would take complex reverse engineering way beyond what I am capable of let alone willing to do given these are commercial products, but I do think it is very valid to consider the general principles eg what are the factors that determine the actual room temperature, and then see what we can do to reduce costs while maintaining comfort, which at the end of the day is what most of us want.
On the question of recovery after a power cut (which we have a fair number of, rural location with overhead lines) - I have deliberately made my setup as resilient as possible. The mini PC that runs the show is set to reboot after a power cut, and then various scripts including dare I say it a residual Home Assistant installation auto-restart. The main failures I get at the moment are HA logging conking out with "Unknown error OverflowError('int too big to convert')" the cause of which I have not been able to find (I can track down the code that logs the error, but not what triggers the error), which I fix by having a HA automation detect the error, and when it occurs, it reboots HA.
The reason I still have HA (for those who know my general views on HA) is purely historical. It's been on my system from day one, installed as part of the initial installation, and although I have increasing moved away from it, it does still have some useful functions, and rather than re-invent the wheel, I have let HA carry on doing what it does perfectly well.
I know this thread is quite old, but I have been searching for info on the Auto Adapt feature, and there is an outline explanation in this Mitsubishi video:
- 2,539 Topics
- 59.1 K Posts
- 425 Online
- 6,818 Members
By JamesPa , 3 hours ago
By JamesPa , 4 hours ago
By Boycey , 6 hours ago
By ChandyKris , 7 hours ago
By JamesPa , 8 hours ago
By Papahuhu , 8 hours ago
By Majordennisbloodnok , 9 hours ago
By TechnoGeek , 10 hours ago
By Gruff2001 , 12 hours ago
By Papahuhu , 12 hours ago
By antonical , 14 hours ago
By Mars , 14 hours ago
By Mars , 15 hours ago
By JamesPa , 16 hours ago
By RobS , 1 day ago
By antonical , 1 day ago
By Boycey , 1 day ago
By Judith , 2 days ago
By antonical , 2 days ago
