Mains water pressure
when my air source heat pump was installed I think the cold water was no longer fed from a tank in the loft but fed directly from the mains. Does that make sense?
It now makes a lot of noise when the cold tap turns on and toilets flush, washing machine fills etc. As it turns off there is then a large clunk noise.
any thoughts how to solve this?
thanks
Check to see if you have a loose pipe where you hear the clunk you speak of. It’s very likely a result of the plumbing being diverted.
Thanks will do.
did anyone else find the system is over-pressured since the ASHP was installed?
Hi @bridgetjohn
Yes ! We had a vented system prior to the ASHP, we now have an unvented system, so mains pressure in all the hot and cold taps. We have 2 loos, one is same as ever, the other sends a thud down the pipework when the flow shuts off. It's been suggested that the answer is to fit a different valve in that loo: a Thomas Dudley Hydroflow bottom entry ball valve !! It's been on my list of 'to do' items for months, meanwhile I've got used to it. Thanks for reminding me.
- 2,783 Topics
- 65.6 K Posts
- 2,146 Online
- 7,187 Members
Without doing some research I can't immediately answer ...
By JamesPa , 12 minutes ago
Political suicide given that the vast majority depend o...
By JamesPa , 1 hour ago
Excellent find, thanks for posting the link here.
By cathodeRay , 6 hours ago
For Powerwall calibration, avoid forcing repeated deep ...
By EnergyStorageTech , 7 hours ago
By bobflux , 19 hours ago
All the 45° elbows required for getting the primaries i...
By Singlespeed , 20 hours ago
By bobflux , 2 days ago
By Andris , 2 days ago
By Papahuhu , 3 days ago
By Batpred , 3 days ago
By Rob of York , 3 days ago
By downfield , 4 days ago
By Mars , 5 days ago
By ian33a , 5 days ago
