@toodles June figures confirm my GivEnergy app AND portal both returning incorrect data
GIVENERGY
Import 579.1
Export 829.3
Solar 747.75
METER readings taken early on 1st june/1st July. Slightly out of sync. Will update with Octopus readings once they're in that app. Usually a day or so later
Import 939
Export 1227
Without doubt true solar prod is higher. Perhaps circa 900.
June 2024 was 853
June 2023 was unknown as inverter outage for 2 weeks. At a guess 800. May 760, Jul 652
June 2022vwas 773
Meter imports & exports seem right as I'm force charging batteries at night and force exporting in day (on IOG tariff)
Ideally would like to install another app to monitor solar in particular - not sure if that's possible without going to effort of installing Raspberry kit or something?
I have an EM115 meter in standalone consumer unit ... I guess I need to look at those readings. Perhaps the EM115 has problems
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
@tim441 Bearing in mind my 8.1 kWp. array is not ideally orientated and that I do have some issues with part-time shading, my production is fairly respectable I think. I have 5 panels on the house roof (one being in proximity to the chimney) facing SWW, two on the old garage roof facing SE, four on a flat roof facing SE and ten garden mounted facing SSE. From May to September, the majority of panels are above any shade lines by ~09:30 and remain clear until ~18:00. Regards, Toodles.
Oh, and I might add that each panel has its’ own Enphase IQ7A microinvertor. Toodles.
My old system is 2kw. S facing. Pitched roof. Solaredge optimisers. Mostly good sun with a chimney that shades 1 panel in particular in the morning.
My newer system is 6kw. E facing on near flat roof. 5 deg pitch. No optimisers- I think panels are supposed to have some "intelligence" meaning optmisers/micro-inverters not necessary. No major shading now neighbouring tree has been reduced in height and shape. Reasonable production in afternoon as sun goes round during pesk months
In my view pitch and orientation are not critical. Possibly reduces my output by say 10% or less.
Shading is clearly important.
My flat roof panels can be cleaned by me ats single storey. Normally try to do it 4 times a year to prevent build-up. But that means no big difference is noticeable!
8kw pv solar
MG4 EV
@tim441 I can and do keep 12 of the 21 panels clean with a brush and rainwater; the other 9 are out of safe reach though. 😏 Toodles.
@tim441 I asked Wattson:
“Intelligence” in the context of solar panels refers to the smart technologies and systems that optimise how solar energy is generated, managed, stored and used within your home energy setup. This intelligence helps maximise efficiency, savings and sustainability by making your solar PV system more responsive and adaptive.
Here’s what that typically involves:
Smart Inverters: These convert the DC electricity generated by solar panels into AC electricity for your home and the grid, while managing voltage and frequency to improve efficiency and stability.
Energy Management Systems: These monitor solar generation, household energy use, battery storage and sometimes your heat pump, to intelligently control when and how electricity flows. For example, they can prioritise using solar power to run your air source heat pump (ASHP) or charge your battery.
Smart Controls and Automation: These systems can automatically decide when to store excess solar energy in batteries, when to draw from the battery, or when to export surplus power to the grid. They can also respond to time-of-use tariffs or grid signals to reduce costs or support grid stability.
Data Analytics and Monitoring: Intelligent solar setups provide real-time insights and historical data on energy production and consumption, helping you understand your system’s performance and identify opportunities to save energy and money.
In short, intelligence on solar panels means using technology to create a smart, integrated energy ecosystem that maximises the use of renewable energy, reduces reliance on grid electricity and enhances the overall performance of your heat pump, PV and battery storage system.
If you want, I can explain how these intelligent systems work together with heat pumps and battery storage to create a seamless, sustainable home energy solution!”
So that’s that then! Sounds very much like microinvertor functions to me! Toodles.
@toodles all depends on asking the right questions! And I probably led you down the wrong path.
Shade Tolerance
MPPT on individual cell-strings optimizes energy harvest.
Built-in Cell Optimizer
No additional electronics or hardware required; allows for simple installation.
8kw pv solar
MG4 EV
@tim441 Well it looks like the micro inverters have been working that bit harder this July compared with the previous July’s in ‘24 and ‘23. Considering the second half of the month was a bit ‘meh’ with many clouds most days - I’m very pleased; couldn’t quite make the MWh though! Regards, Toodles.
My GivEnergy app is no longer recording data correctly. I think others have same issue as well. GivEnergy keep denying issue. Disappointing.
But the main thing is the meter is working and I'm seeing correct exports.
Givenergy app said July:
1. Production: 777kwh
2. Exports: 755kwh (includes forced exports etc)
Small Solaredge system produced 226kwh according to its own meter.
So total solar just broke 1mw
Metered exports actually 1127kwh. Which I'm very happy with. Includes forced exports from batteries (filled at night on IOG at 7p)
So far I'm averaging imports at under 7.5p since switching to IOG in early Feb.
I'm living in hope that I may get close to importing around 13000kwh this year including force filling batteries for export, EV, ASHP & general usage. If that costs circa £1000 it will be fantastic result. Just depends if ashp draws much at higher rates this winter. We don't plan to be cold!!
Exports should exceed 6000kwh including solar & forced exports. At 15p = £900
So net cost might be close to zero in best case scenario. Something I never thought possible and transforms the ROI.
In reality a net cost under £1000 will still be excellent
8kw pv solar
MG4 EV
@tim441 fantastic!
My current direct debit is £50/month. We shell see by January how i will come out. Do I have to raise it or lower it.
I've reduced my debit to £10/month
For end July it should be around £500 in credit. Perhaps going into heating season with £750 credit... which may be sufficient. All depends on the draw at higher daytime rates.
8kw pv solar
MG4 EV
1 month ago
1 year ago
2 years ago
First 6 months
3 years ago
- 2,123 Topics
- 46.7 K Posts
- 42 Online
- 4,531 Members
By benson , 13 hours ago
By Majordennisbloodnok , 14 hours ago
By Toodles , 15 hours ago
By Scalextrix , 22 hours ago
By cathodeRay , 4 days ago
By Judith , 4 days ago
By Old_Scientist , 5 days ago
By DavidAlgarve , 5 days ago
By AllyFish , 5 days ago
By Transparent , 5 days ago
By Papahuhu , 6 days ago
By Transparent , 6 days ago
By Mars , 6 days ago
By JulianC , 1 week ago
By Judith , 1 week ago
