Solar panels on side of house to heat water
Posted by: @paultheheatingThank ou all for comments, just to refocus I am not looking to install anything complicated that needs certification, maintenance, am not fixed to 4-6 panels could put in one or two panels if that is enough to bring cold water up to 20-30.C In reflection I should have said
does anyone have a dc immersion running off vertical panels to reduce gas consumption, is there a switch that can turn off panels if they produce too much heat energy.
Just a quick note, as this system would not even connect to anything outside your home and makes no use of grants, I cannot see any need for notification let alone certification..
PV panels that are not supplying anything just sit there, so when the tank is warm enough, the heating element just needs to switch off. I imagine all hot water tanks have a thermostat for this.
16kWh Seplos Fogstar battery; 8kW Solis S6-EH1P8K-L-PLUS hybrid inverter; Ohme Home Pro EV charger; 100Amp head, HA lab on mini PC
Posted by: @paultheheatingjust to refocus I am not looking to install anything complicated that needs certification
My solar panels (both PV and thermal) have not required paying for professional installation.
What I'm telling you here has been achieved on a DIY basis, and I can provide you with suppliers' details.
@batpred is right.
- You only require permission from the DNO if you require a grid connection which can export power
- You only need MCS-accredited installers if you want to sell your electricity and obtain income via the SEG (Smart Export Guarantee)
- You only need a qualified electrician if you're installing mains wiring and devices within the fabric of the house (above 75v AC)
For everything else, you only need to obey the Safety at Work regulations for 'working at height' (yes, that applies to home-owners too)
and make sure you're not invalidating the terms of your home insurance.
Just think about this on the basis of 'common sense'.
You don't employ an electrician to run a 4-way mains distribution lead for example, but you might want some advice about the capacity-rating of that cable in amps.
That's where this forum can help
- 2,364 Topics
- 53.6 K Posts
- 293 Online
- 6,029 Members
RE: ASHP sizing - value of Heat Transfer Coefficient
Sorry, but I cant see what the point of this is unless ...
By JamesPa , 4 hours ago
TC Thermostatic Radiator Valve TRV Plastic Decorators S...
By Toodles , 8 hours ago
RE: Ecodan unable to hit legionella target temp - what's the consensus?
UPDATE: Thanks everyone who commened with suggestions h...
By 9jwr9 , 12 hours ago
How long will your energy contract last?
Some heat pump tariffs don’t run as long as a heat pu...
@morgan They are unsupervised these days, can’t get the...
Exactly. We only need to compare conditions, to decide ...
By cathodeRay , 4 days ago
I found because I have very low heat loss I can set bac...
By RadWhisperer , 4 days ago
RE: Need Help Optimising My Rushed ECO4 Install: 12kW Bosch Heat Pump
Welcome @mickamills We too have an oversized 12kW Sa...
By Old_Scientist , 4 days ago
RE: My Powerwall 3 Consumes 3-4 kWh/Day in Self-Consumption: Is This Normal?
@caron I can confirm that the power usage of the PW3 is...
RE: Speedcomfort radiator fans
Thats true, but having tried (and succeeded) in constru...
@bash brilliant, thanks for the feedback
By energy9165 , 4 days ago
RE: Heat Pump Heats the House… But It’s Not Cosy. Emitter Changes or System Tweak?
@alastair There I was, feeling grumpy, he said “Cheer u...
By Toodles , 4 days ago
RE: Grant Aerona: Is there a setting to keep the 2-port valve open during pump blockade
Depends on OAT. Mine cycles at OAT>10 and of course...
@transparent My conclusion is as you have noted, tha...
By Bash , 4 days ago
RE: Mitsubishi Ecodan R290 10kW performance
And to you too. Wishing you a very enjoyable festive s...
RE: External pipework insulation
They do? But that isn't apparent from the photos we'r...
@velcro welcome to the forums. Please feel free start a...
By Mars , 5 days ago
Daikin EDLA11D3V3 DHW Settings
I have a newly installed EDLA11D3V3 which I'm still get...
By Velcro , 5 days ago
