And we have it:
DESNZ are now investigating the feasibility of balcony solar. Good start but please ignore some of the utterly stupid comments ("we don't have plugs on UK balconies" 🤦🏻♀️)
Offstage: [we don't even know how to build balconies in this profiteering, cheapskate country but hey...]
Maybe for 'proper plug-and-play' (as opposed to how we currently wire mini systems into CUs) the answer is not to copy but adapt - find a way to have an interface between mini inverter and distribution grid (I'm being deliberately broad here before y'all jump 😁).
Anyway, it is a necessary step forward - we must find ways to bring tenants and flat dwellers into decarbonisation. And... maybe it will inspire smart designers and entrepreneurs to design a simple system or interface.
As for the £2000 suggestion..... if you are a home owner you can do it much cheaper already including paying a qualified spark for wiring to satisfy building regs . But never mind, it's a step in the right direction.
Posted by: @lucia...
Actually I'm going to jump but in the same direction as you, @lucia.
It is an inescapable fact that, on the Continent, it is possible to buy a small, cheap solar PV system, plug it in and supplement one's home electricity supply with the power it generates. It is not, however, possible to do the same thing in the UK. That fundamental inequality is all that really matters; anything else is just fluff. Removing that gap is not going to be achieved by focusing on why it's impossible in this country and I believe we need instead to do what an old boss of mine used to call "taking away someone's reasons to fail" - steadily providing answers to what "can't" be done until all that is left is a pathway to success. Precisely what you're suggesting, of course, by highlighting a bit of judicious adaptation instead of copying.
Ultimately, I find it hard to believe that the collective technological knowhow in the UK cannot come up with a simple way to achieve what's already being done in other countries. Yes, there are differences and therefore different obstacles to tackle but it's not rocket science. And I wholeheartedly agree that all those who don't own a physical roof and/or the wherewithall to equip a roof with solar panels should be offered realistic and affordable ways to live more sustainably.
balcony solar panels are available in UK, search Amazon for them, here’s a site specialising in them
https://solarplanet.uk/the-complete-guide-to-balcony-solar-panels/#IV.%20Installation%20and%20Setup
Posted by: @agentgeorgebalcony solar panels are available in UK, search Amazon for them, here’s a site specialising in them
Have a read of my previous posts on so-called Balcony Solar (there’s a sum up of the state of play in my older post just above my post today).
There’s a huge difference between the small UK micro systems that by law still have to be wired in to a Consumer Unit (no big deal not like rooftop solar) and the plug-and-play systems sold in Germany and elsewhere in Europe.
It’s the latter that DESNZ is now investigating.
Solar Power Output – Let’s Compare Generation Figures
7 days ago
1 year ago
2 years ago
Solar panels not working correctly? what checks can I make?
2 years ago
Cleaning solar PV panels? to increase output
2 years ago
- 2,104 Topics
- 46.3 K Posts
- 61 Online
- 3,393 Members
BUS Grant, removal of all other heat sources
Hello, we are in the middle of a air source heat...
By Rikiarn , 2 minutes ago
@agentgeorge, I was also more interested in using a car...
By Majordennisbloodnok , 58 minutes ago
By ChandyKris , 1 hour ago
Good point. I wonder if anyone here knows someone in th...
Yes. Just focusing on specific months, our average impo...
By rossowheels , 22 hours ago
By Lucia , 2 days ago
By Scalextrix , 2 days ago
By Damon Blakemore , 4 days ago
By Mars , 5 days ago
By downfield , 5 days ago
