Hm, 404..
I've checked this one )
Or "Renewable Heating Hub Forums -> Grounds Source Heat Pump (GSHPs) -> DIY Heat Pump controller (driver)"
@gonzho Thanks, it looks to be a very basic controller, but interesting. What levels of performance are you achieving?
We are developing a unit that will commission and run the system autonomously, producing the best possible performance with the attached heating system.
@heacol It depends.
It depends on a heat exchangers type (plated or DIY), exchangers surface (m2), floor and ground loop performance (m2 of liquid per hour), required floor temperature (K), actual ground temperature (K) (autumn: lot of heat, early spring: no heat). Required floor temperature is a subjective factor, human-dependent. Other factors are objective.
What conditions exactly are you interested in? )))
Oh, and refrigerant type + exact compressor model (and of course compressor type), regenerator performance (if used), and may be something else.
Performance comparison is a good question, but not as easy as it sounds )))
Hi Im Graham Hendra, heat pump geek and tech support engineer. I spend my life helping the engineers stood in front of your heat pumps over the phone and on youtube. I advise engineers, homeowners builders etc on matters heat pump. If i can help just ask.
Heat pump builder
@gonzho I am interested in overall performance, preferably on an annual basis SCOP in other words, Instantaneous performance bears little resemblance to the cost of running a system. The heating system (radiators, under floor etc) has more influence on the cost of running a system than the heat pump it'self. I have seen heat pumps with a very poor instantaneous COP, on a good heating system, outperform good units on bad heating systems. In reality, if you put all the heat pumps on the market together, in the same lab, they will all have similar performance levels. You are dealing with the laws of thermodynamics, which cannot be beaten.
At the end of the day, the only things that counts is a low heating bill, good comfort levels and good reliability.
@grahamh, welcome to the forums and for offering to share your extensive knowledge with the users here. Massively appreciated, and thank you for taking the time to be interviewed yesterday - it was great fun and we learnt a lot.
@grahamh Hi Graham, Fancy seeing you here!!!
Hi all, just joined to help me understand all the information thats out there and make some decisions around how to heat my house. Thanks for all the info so far 🙂
@lewyh, welcome to the forums.
Hello!
I found your site after watching one of your YouTube vids. The first content I saw here was the interview with Graham. When it first started I thought "oh no, a 45 minute video about heat pumps!" and expected to give up after a few minutes. However, 5 minutes in I was hooked and watched it all the way to the end. What a great video! Graham is clearly very knowledgeable and his enthusiasm comes across in bounds.
After watching that, I started reading through the forum posts and found them to be a mine of useful information. I have just registered to say thank you, and in the spirit of contribution I will share my journey with everyone here.
I live in a converted barn in Monmouthshire (South Wales). It was converted around 10 years ago and we bought it 7 years ago. It currently has an oil boiler which has been working well. However, last month, our oil delivery driver spotted a tiny crack in the top of the tank and refused to fill it up. We immediately entered 'panic mode' at the fear of running out of hot water (not using heating at the moment but that will be needed in the next month or so...) as we only have about a quarter of a tank left.
I initially reached out to a couple of local heating companies to enquire about replacing the oil tank. It turns out that our current tank is located in a position that would not comply with current build regs (and probably never did) and so replacing it involves more than a simple swap-over: we'd have to either relocate it or build a fire-proof barrier around the tank to meet regs. Most companies didn't want to touch it with a bargepole, although one firm quoted £3,500 to replace the tank and make it regs-compliant.
Over the last few years, we've gradually installed air to air heat pumps in most of our rooms because in the summer the house gets very, very hot. It's south/south west facing and we have lots of floor to ceiling glass, so it basically acts like a greenhouse. We've been really pleased with the low running costs, which made me think about exploring using an electric system to replace the oil boiler.
Much googling later and I made a few enquiries to local MSC accredited ASHP installers. Our house should be well suited to ASHP because we have underfloor heating throughout - no radiators - and I was also optimistically hoping the costs would be favourable with the RHI scheme.
5 weeks in, I have:
* received one quote of £9.5k for install of 7kw Valiant Aerotherm Plus, 200ltr Valiant tank and Valiant controller. Estimated RHI payment of £9.1k. The quote was based on floor plans, an EPC from 2013 and the building survey we commissioned before buying the house. They've emphasised it's an estimate and will be confirmed after paying £500 for them to do the heat calc survey and new EPC. Originally I thought these guys were good, but I've emailed and phoned a couple of times over the last few weeks with questions and they've stopped getting back to me. Maybe they're just too busy.
* received one quote of £18.9k for install of 2 x 10kw Valiant Aerotherm Plus, 200ltr tank and controller. For this one, the company sent someone out to do a free heat loss calculation - they were here for about 2 hours measuring all the rooms up, so I'd imagine the 2 x 10kw spec is right but am hoping it is way over-egged. They've not included any information on estimated RHI payments.
* had a visit from a company to do a quick initial assessment and chat, he estimated 12 - 14k but wouldn't be able to give a final quote unless I paid £299 for a heat loss calculation.
* had a visit from another company to do a quick initial assessment and chat, he estimated 14 - 16k but wouldn't be able to give a final quote unless I paid £250 for a heat loss calculation. I actually felt the most positive about this company, all my communications with them have been really good, they are clearly knowledgeable and appear to have a good reputation. They also promise a 10 year parts and labour warranty, which is way more than the others. They have only been in business 4 years though so how worthwhile this will be remains to be seen. That said, I agreed to pay the £250 for the heat loss calculations, this happened last week, so I am expecting to hear the results of that and get a final quote in the next week or two.
I've found it really hard to assess and compare suppliers, particularly because they are unable to quote without first paying for the heat loss survey. Annoyingly, none of the companies were willing to accept heat loss survey results from another company, which would effectively mean paying for the same survey several times just to get comparative quotes.
One potential pitfall to my switch to an ASHP is needing a water tank. Our current system is a combi oil boiler and we have no standalone tank. We don't have any suitable space inside the house to locate a tank. Three of the suppliers so far have said we will be fine to locate the water tank outside next to the ASHP if we build a suitably insulated wooden shed structure. One supplier insisted this was a terrible idea and said the tank must be inside the house. I don't know who to believe. I'd welcome input from anyone in a similar situation.
I'll update you all in due course...
- 2,136 Topics
- 53 Online
- 5,662 Members
The problem is bigger than rented properties, it applie...
By JamesPa , 57 minutes ago
We got lucky and hit gold with our installer. Rather th...
By Old_Scientist , 1 hour ago
@robs Hi Rob, I really appreciate your information, a...
By DavidAlgarve , 2 hours ago
What limit are you speaking of. So far I was aware dno...
By JamesPa , 4 hours ago
By SAEnergy , 5 hours ago
By Tim441 , 10 hours ago
By Temperature_Gradient , 13 hours ago
By Toodles , 19 hours ago
By Mars , 21 hours ago
By GrahamF , 2 days ago
By ASHP-BOBBA , 3 days ago
By bontwoody , 4 days ago
By Old_Scientist , 5 days ago
By DavidAlgarve , 6 days ago
By Transparent , 6 days ago
By Old_Scientist , 7 days ago
