Thinking of ripping...
Thinking of ripping our my IVT Greenline HT Plus C model and replacing with a gas boiler.
9 Users
5 Reactions
(@abbote)
We designed and built our own house around a GSHP in 2011, because we wanted to do the right thing, even though we had mains gas. This year it has developed many issues and alarms and has finally now stopped working. With sub-zero outside weather I'm rather desperate!
No one seems to know anything about it, I'm over £500 down just having 3 separate 'expert' heating engineers stand there and let me shown them how it works and them to scratch their heads and walk away and send me a bill. On top of this it took me a while just to get someone to come and look at it, we had no heating in November.
Is there anyone out there that can help?
The main issue seems to be a HTF alarm (GT8/GT9) and then a HTF max which trips the unit out. I'm told there should be a particulate filter but cannot find it, I know it's not in the inside of this model, so it might never have been fitted.
I increased the alarm threshold and lowered the water temperature to force the pump to drop into rad heat in order to get heating into the house. This was in November, and it's limped through to now, but the GT8 temp has increased to over 70 with a GT9 at sub 30, and with water temperature of only 40. Now cannot get it to jump to rad heat. If I try add heat to get it to cycle the water temp to over 60, then a electrical cassette alarm triggers.
Alto Energy have been quite helpful and have told me to drain the system and check the flexible hoses below the electrical cassette, but this is beyond my abilities and when I have suggested this to the heating engineers, then don't seem keen either?
I have been given a quote to install a Worcester Bosch gas boiler and HW tank, it's quite eye watering after spending £25k on a system I thought we would get 20-30 years out of, however, it's a lot cheaper than a replacement GSHP.
Its a fact that there are more engineers out their that understand gas boilers, and very few that are either interested or have knowledge of heat pumps.
On top of this the increase in electricity/kWhr has really also enforced my belief that we are just not ready to heat our homes with this technology.
Do you know what the alarm means.
From what you 'have been told' it sounds like a 'low flow' alarm.  If it wasnt there initially then something has changed to increase the system resistance and thus reduce the flow.  The most likely candidate is a blocked filter (Im basically agreeing with the advice you have received).
Both gas and heat pump central heating systems have filters to take out the crud (technical term!) that accumulates from the inside of the radiators.  They need to be cleaned out every so often and if they aren't you can get a low flow alarm (or the consequences of low flow) with either.  The recommendation is often to clean them out annually, but in practice they may last years (depending on your emitters) before they become a problem.   That's just how it is with central heating systems.
They are typically roughly cylindrical about 10cm diameter and 20cm high.  Google "Magnaclean" which is one example, or "Spirotech" which is another.  It will be most likely be fitted close to the main unit in the main pipework which is the 'return' ie is bringing water from your emitters to the heat pump, or less likely it maybe just inside the unit (check the manual).  If there isnt one, then the likely consequence is a blocked heat exchanger in the heat pump, which is not good news.  A gas boiler suffers from exactly the same problem.
The next most likely problem is a water pump fault, but if you haven't cleaned the filter then everything points to the filter.
Since these filters are used in most central heating systems any plumber worthy of the title should be able both to find and fix it (or if you can find it then its a simple DiY job).  Of course not all plumbers are worthy of the title.  Feel free to post some pictures in case I or someone else can spot it.
On the matter of running cost do you know what COP you are getting and have you explored alternative electricity tariffs.  There is no reason, with a half decent heat pump set up and an appropriate tariff, why you should be paying anything significantly more than you would pay for a gas fired system, and you might well be able to pay less.
This post was modified 1 year ago 5 times by JamesPa
Further to the above I found the manual here
Page 37 describes the alarm and possible reasons, of which a blocked filter is one.
Page 29 describes the particle filter which is, it seems, integral to the pump (but may nevertheless be fitted externally depending on your model - see page 29).  It also describes how to clear it which does not require draining the system (but does require a pair of 'supplied' circlip pliers, probably now discarded but obtainable from eg Halfords)
You may in addition have a third party Magnaclean/Spirotech filter a blockage in which would have the same consequences and cause the same alarm so far as I can tell.  So its worth looking for this as well.
Hopefully that helps.
This really should be an annual maintenance action, but I guess many people (including me) don't actually bother with annual maintenance of heating systems.
PS, for transparency I'm neither a plumber nor a heating engineer.  I have a physics degree and spent 30 years in engineering, so have a bit of a 'nose' for this sort of problem, but essentially zero specialist knowledge.  (This may or may not be a disadvantage, because I know essentially nothing I am forced to work almost everything out from first principles, which generally turn out to be extremely simple and common to multiple systems.  However please note that this means I can also get caught out!)
This post was modified 1 year ago 6 times by JamesPa
(@abbote)
Many thanks for taking the time to reply. There is a Magnaclean on the return from the rads/UFH, which I have cleaned myself, is this just the white plastic filter and actual magnets that you clean and there is no other cleaning necessary? I have tried to upload a pic, but for some reason won't let me.
There should be a particle filter on both the cold feed and the hot flow and return, as mine is the C line with the hot water tank inside the unit, both are external to the pump, however, I think my installer, who was pretty useless maybe forgot to put them in.
I'm also a mechanical engineer by apprenticeship and degree, which is why I probably know more than the heating engineers that visited. Unfortunately, it's a matter of confidence of not screwing it up completely at this time, as I've managed to get the pump into limp mode by lowering the water temp to 35 and also bring the heat curves down, this way the GT8 temp remains below the cut out temp and I get a little heat into the house. However, the anti-legionnaires function, ie heating the water to 65 will not work.
Thanks for the manual too. I will check if this is the same as the one I have.
Posted by: @abbote
I can see the magnaclean.  I cant remember whats inside TBH but that sounds about right.
Posted by: @abbote
Oh dear - its just possible that the heat exchanger could be blocked then if these aren't present and you have a flow problem.  Is there any way you could flush it through?  Of course there are other possible explanations for a flow problem but filter blockage this is definitely the most likely.
Posted by: @abbote
I think you have put your finger on why this might be better as a DiY job!
(@abbote)
As I thought I've been told that the most likely cause if the internal flexible pipes below the electrical cassette and flow pump. It's great that the price of these pipes is only £146 inc' VAT but so far the best cost I have for their replacement is £1,000 ex VAT, and that's only for 0.5 days labour. I'm still leaning towards ripping it out. Is there a market for second hand spares or repairs IVT GSHPs?
Posted by: @abbote
That's a pity, the most expensive part of a GSHP is, SOFAIK, the underground bit by some margin, which you already have!
Unfortunately we live in a throwaway society where nobody wants to (or knows how to) repair anything, and if they do wants to rip us off big time.  Its true across the whole spectrum of 'consumer' goods.
rob_cirrus_energy
(@rob_cirrus_energy)
@abbote Hi there,
Well done with all the fault-diagnosing you have done so far and sorry to hear that you have been having such issues with your system.
Did you manage to locate the particle filter and get it cleaned?
Heat pump consultant and designer at Cirrus Energy.
Thinking about installing a heat pump? Or already have one but it’s not performing as it should? Book a one-to-one session with Rob to discuss things here.
(@greenlight)
Don’t rip out a IVT! Amazing heat pump! Unless your compressor fails or your tank fails is the only reason to take one out.
It sounds like you have terrible flow, change the braided hoses and upgrade the circ pump.
High delta T means poor circulation, if you have that on heating and hot water then it’s braided hoses.
See this old video I did on braided hoses
(@pike005)
New Member Member
Apologies for hijacking this thread but it is on the same theme.
I have an 18 year old Greenline IVT 9Kwh GSHP.  It has been mostly well behaved apart from the electrical cassette failing around 6 years ago and the control panel becoming tempramental.
The pump cut out 5 days ago and resetting the trip switch didn't restart the usual countdown, and nether did it trip the switch again.   The display is not showing any life.   An engineer came out and isolated the likely cause as the main Rego 600 Control box failing.   Apparently these have been discontinued and new ones aren't available, but I believe reconditioned ones might be available  - waiting to find out.   When new the replacement would cost around £900.
I has made me wonder whether it's worth spending a sizeable amount of money on an 18 year old pump where parts are now going out of supply likely to start to fail in other areas and expertise is limited and replacing with a 9KW ASHP.
 Any thought if anyone else has gone through this process  - or has experience of costs of maintaining old Greenline pumps?
@pike005 looks like your Greenline has done well to last 18 years, but with parts like the control box becoming scarce and expertise dwindling, you’re right to question whether it’s worth investing further. Spending £900 on a reconditioned unit might keep it going for a while, but there’s always the risk of other components failing soon, leading to more costs and hassle.
Switching to a modern 9 kW ASHP could be a better long-term solution. Whenever I ask experienced installers a similar question, they always suggest going for something newer because it’ll be more efficient, quieter and come with better warranties and support.
If budget allows, I’d lean toward replacing the system for peace of mind and future-proofing. But if you’re not ready for that yet, repairing the Greenline could buy you some time to plan. Either way, it’s worth getting a few quotes and weighing up the options.
(@derekdeleon)
@pike005   I would be sorely tempted to go crazy and replace the controls with one of these control units (eBay item number:286418304853), which is meant for an ASHP but I bet it could be persuaded to work...for £32
Would be a great summer project 😀  If it's knackered anyway.........
Page 1 / 3
