RDSAP10 effect on existing heat pump EPC rating?
Good point... this slipped off my radar, and I've not really heard much about what to expect.
Posted by: @af1Hi. RDSAP10 coming into force on 15th June 2025. Will EPC rating improve substantially for Heat Pump properties?? Maybe get from D to C?
RdSAP 10 represents a significant shift in how EPCs are calculated, particularly for properties with heat pumps. The revised methodology places greater emphasis on carbon emissions and gives more accurate credit to low-carbon technologies, smart heating controls, and integrated systems such as solar PV and battery storage. In theory, this should result in a notable uplift in EPC ratings for well-insulated homes with documented installations—potentially moving them from a D to a C rating. However, the practical reality is more complex. The accuracy of any EPC assessment under RdSAP 10 is heavily dependent on the quality of data input, which in turn relies on the availability of supporting evidence like installation certificates, specification sheets, and test results. Unfortunately, there is a persistent issue in the industry: many clients are reluctant to cover the cost of the additional time required for a comprehensive survey. As a result, assessors—working within limited budgets and tight timeframes—are often forced to rely on default values, which can significantly understate the true performance of the property. So while RdSAP 10 brings the potential for more accurate and favourable ratings, without proper engagement and investment from clients, much of that benefit risks being lost in practice.
@aaron Great response, thank you. Yes I already knew that Proof of all aspects is the key. I have everything regarding Glazing, GSHP, MVHR, EWI except the cavity fill certificate so I have emailed CIGA. I had paid £300 for an SPF report for RHI.
On the lighter side, in this brilliant spoof, the legendary Ken Bone plays both the homeowner and the EPC inspector, capturing the absurd reality many UK homeowners face when renewables clash with outdated energy assessments. From heat pumps being ignored to solar panels dismissed as “ugly,” this tongue-in-cheek sketch shines a spotlight on how EPCs often miss the mark.
@editor very good!! Im surprised he got the assessor into the property..
This is exactly why we don’t use RdSAP—it’s designed for speed and simplicity, not accuracy. We carry out all our assessments using full SAP software. It takes more time and effort, and yes, it does cost more—but the results are significantly more accurate and reflective of the building’s actual performance. When you're making decisions that affect long-term energy use and compliance, it's worth doing it properly.
@af1 if all of those features (GSHP, MVHR, double glazing, full loft insulation, and 100mm phenolic EWI) weren’t in place at the time of the last EPC, then yeah, you should see a significant jump in the rating when it’s reassessed.
- 22 Forums
- 2,082 Topics
- 45.7 K Posts
- 17 Online
- 3,370 Members
@af1 if all of those features (GSHP, MVHR, double glazi...
By Aaron , 20 minutes ago
That is something @bart would need to tell us. I have m...
By MPHB , 35 minutes ago
RE: To relocate or add extra PV panels..advice required
The situation you are currently experiencing is represe...
By apollogrid , 8 hours ago
no it’s not it just a search of user manuals , being ca...
By Alfapat , 15 hours ago
RE: I don't need any heating in the summer. How do I turn my Samsung heat pump off?
SmartThings indeed allows remote control over the heat ...
By HCas , 16 hours ago
RE: Air Changes per Hour - ACH and the MCS requirement
@jamespa I have not had a heat calc yet that is below 4...
By ASHP-BOBBA , 17 hours ago
RE: Remaining hot water/hot water flow meter
@lakey Hi, I had a quick read through and wanted to see...
By ASHP-BOBBA , 19 hours ago
RE: I worry I've messed my Samsung settings up somehow
@ecobaker I missed this, sorry So 3031 was set to...
By Joshua , 22 hours ago
RE: Flow Rate & Low Loss Headers
It sounds like you have thought about this a lot and ev...
By JamesPa , 23 hours ago
@old_scientist thank you, and thank you to @Morgan for ...
I am a UK based product manager for an energy storage s...
By shawnlee , 1 day ago
RE: Thinking of ripping our my IVT Greenline HT Plus C model and replacing with a gas boiler.
That's great and in principle I wouldn't disagree, but ...
Mitsubishi 8.5 kW Ecodan Standalone (PUZ-WM85VAA)
By Nell , 2 days ago
This is the plan to get our next heat pump installed an...
Thanks! That is most useful. I've had a look at the Mid...
By benson , 3 days ago
I found that Homely blog a few days ago and was tempted...
By cathodeRay , 3 days ago
I love that! Unfortunately there doesn't appear curr...
