Zehnder ComfoPost CW6 with ASHP?
I am considering replacing my gas boiler with an ASHP and also upgrading my MVHR system. A couple of items I am considering are the Zehnder ComfoPost CW6 and the Zehnder NOX40-125. Space is tight and a careful design will be required. I would also like to improve the acoustic insulation of the loft space where the main MVHR components are installed.
Does anyone have experience of using a chiller like the CW6 attached to a cooling circuit on an ASHP? Last year's heatwave caused uncomfortable overheating in my house and I am interested in potential solutions.
I have tried asking Zehnder for further information but have not received any replies either to forms submitted via their website or to emails sent to a number of their email addresses (and from two of my email addresses). I have even tried whatever the bird site is called this week. I find it really frustrating when companies publish contact details but then don't reply!
Posted by: @fazelWhat exactly did you ask/want to know from Zehnder?
I would like to know if they offer design advice and can recommend installers that might consider upgrading my existing system. There is a good supply of technical information available on their website but I am not an MVHR system designer. The existing system was specified by the architects on an earlier project and installed by contractors chosen by them.
It would be reassuring to know that should problems occur they would respond to technical support requests, even if they just suggested that the request should be sent elsewhere.
If you want to include cooling, have you considered air to air heat pumps? Depends on the number of rooms you consider needing cooling, and the visual impact of the DX fan coil units internally. Quite a number of air to water ASHPs will heat and cool, but cooling requires fan coil units, either low level radiator style units, or high level ceiling or wall units. MVHR system airflows are unlikely to have a high enough airflow volume to enable DX coils to be added that will be effective. The amount of cooling you'll get out of the them will be very low.
- 2,364 Topics
- 53.6 K Posts
- 310 Online
- 6,029 Members
RE: ASHP sizing - value of Heat Transfer Coefficient
Sorry, but I cant see what the point of this is unless ...
By JamesPa , 15 hours ago
TC Thermostatic Radiator Valve TRV Plastic Decorators S...
By Toodles , 18 hours ago
RE: Ecodan unable to hit legionella target temp - what's the consensus?
UPDATE: Thanks everyone who commened with suggestions h...
By 9jwr9 , 23 hours ago
How long will your energy contract last?
Some heat pump tariffs don’t run as long as a heat pu...
@morgan They are unsupervised these days, can’t get the...
Exactly. We only need to compare conditions, to decide ...
By cathodeRay , 4 days ago
I found because I have very low heat loss I can set bac...
By RadWhisperer , 4 days ago
RE: Need Help Optimising My Rushed ECO4 Install: 12kW Bosch Heat Pump
Welcome @mickamills We too have an oversized 12kW Sa...
By Old_Scientist , 4 days ago
RE: My Powerwall 3 Consumes 3-4 kWh/Day in Self-Consumption: Is This Normal?
@caron I can confirm that the power usage of the PW3 is...
RE: Speedcomfort radiator fans
Thats true, but having tried (and succeeded) in constru...
By JamesPa , 5 days ago
@bash brilliant, thanks for the feedback
By energy9165 , 5 days ago
RE: Heat Pump Heats the House… But It’s Not Cosy. Emitter Changes or System Tweak?
@alastair There I was, feeling grumpy, he said “Cheer u...
By Toodles , 5 days ago
RE: Grant Aerona: Is there a setting to keep the 2-port valve open during pump blockade
Depends on OAT. Mine cycles at OAT>10 and of course...
@transparent My conclusion is as you have noted, tha...
By Bash , 5 days ago
RE: Mitsubishi Ecodan R290 10kW performance
And to you too. Wishing you a very enjoyable festive s...
By Sheriff Fatman , 5 days ago
RE: External pipework insulation
They do? But that isn't apparent from the photos we'r...
By Transparent , 5 days ago
@velcro welcome to the forums. Please feel free start a...
By Mars , 6 days ago
Daikin EDLA11D3V3 DHW Settings
I have a newly installed EDLA11D3V3 which I'm still get...
By Velcro , 6 days ago
