Replacing Worcester...
Replacing Worcester oil boiler with an ASHP
27 Users
182 Reactions
37.9 K Views
JulianC
(@julianc)
I am replacing my 25/32 Worcester oil boiler with an ASHP
Had discussions with many suppliers, a lot of whom wouldn't quote because we have 10mm pipe drops to each radiator, from 28mm loft pipes.
Anyway:  201m2 bungalow.  Built 2001.  EPC rating of B after triple glazing, 300mm of loft insulation.  We currently use between 1220-1500L of oil per annum.  100A incoming circuit.  ASHP approved by DNO (Western Power).   20,500kWh of heating energy required.  3000kWh of hot water demand from the EPC.
An energy loss calc and room by room heat demand has been undertaken.
This has lead me to select Ecobubl from Winchester to undertake the work.  They have proposed a Daikin Altherma 3H HT 18kW ASHP.  Also a Mixergy 150L H/W tank - but we are also considering a standard cylinder with a large internal coil, to maximise the ASHP.  And a 3kW immersion to use my 4kW of PV and Solic 200 electric diverter.  Simple control system, using my current Nest.  Had wondered about the Homely Energy control system, but I wonder if this adds complexity.
Price is £13,700 for ASHP + Mixergy + buffer tank + installation and support for RHI.  I should get back about £10k through RHI.
I will take photos before, during and after installation which should be 12 April
This topic was modified 1 year ago by Mars
It'll be very interesting to compare notes.  Your numbers are similar to ours but a little larger.  Even the price is close like for like although we've had new radiators and pipework throughout.
https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-ashp-installation
Did your installer think your radiators would be OK with the lower flow temps? This will be useful to others replacing existing systems, which I'm sure will become more a more common.
Good luck with the installation and keep us updated!
4
JulianC
(@julianc)
Sure. Your install looks tidy. It is quite difficult to get like for like comparisons because my quotes all had different solutions.
my chap quoted £200-300 per radiator swapped. So that’s why I’m going to try without changes first. 50% of my radiators are single panels with fins. The other 50% are double panel, double fins. The only place I’m concerned about are the towel rails in the bathrooms.
it will be interesting to compare the hot, cold & hot again of a cycling oil boiler to the constant background heat of an ASHP. Although the Daikin HT runs at a hotter temperature than a typical ASHP, I hope to turn it down a bit to save electric costs. We shall see.
4
(@george)
Reputable Member Contributor
We found that swapping out heated towel rails for dedicated bathroom radiators made a huge difference as they actually give off heat instead of retaining the heat on a towel rail.
JulianC
(@julianc)
Useful information George. Thanks
Our ASHP installation date is set for 20th April
JulianC
(@julianc)
E3B0AD5B 37E0 4E11 8ACF E333005C6CA7
E97B0250 94AB 4D74 8115 BE030CC0FF18
The day of my oil boiler replacement with an ASHP approaches. Here is a photo of the boiler cupboard before any work. And my current OSO hot water tank. My installer will remove the oil boiler. Which I have sold on eBay. This will fund the removal of the oil tank.
The oil tank is being removed by a different, registered company
ADAEB8BF 1929 49B6 99CE E58E809F33FA
It will have to be drained (understandable) and then unfortunately cut up, as the company cannot crane it over the fence / hedge you see.
I will next send photos of where the external unit will sit. Exciting
@julianc, that's exciting indeed. The logistics of removing an oil tank must be a real headache, but it's great that everything is taking shape.
This is quite interesting in light of our house - as it transpires, we may have 15mm pipes feeding our central heating, reducing to 10mm out the wall, and this is what is potentially responsible for poor flow rates to the rads in the coldest parts of the house.
I am pleased that we have solved this issue (we will film an update video in a few day's time) by increasing the size of the circulation pump, upsized the rads to K3 units and balanced all the radiators. It's worked a treat.
On that note, have the installers recommended changing any rads as part of the heat emitter guide?
JulianC
(@julianc)
Mars, they have recommended to change 5 or so I think. But they are in bedrooms, so we are thinking to try it and see.
We use a Nest thermostat (which we will continue to use with the ASHP). Currently the Nest never goes above 19.5C. The heat loss & room temperatures were 21C for sitting room & dining room and 22C for the bathrooms. So I’m thinking we should also be ok with the ASHP temperature range
JulianC
(@julianc)
I also like George’s suggestion of swapping bathroom towel rails for radiators
Interesting you should say that; we have 2 ensuites and a main bathroom.  The main bathroom has a towel rail and the ensuites one of each. It was all down to the heat loss calculations; the ensuite with the radiator is on the corner of the house and the towel rail we had space for wasn't enough.  The towel rails were enough in the others and they seem OK so far.
JulianC
(@julianc)
Snap Kev M.  I will wait and see how things go. But of all our rooms, I do like a warm bathroom. 😊
In the meanwhile, this is where the outdoor unit will be located - roughly where the pallet is leaning.  Pipe work will go through the garage under the window. The hydro box will be located in the garage, behind where the external lamp is.  If you look carefully you can see the current oil boiler flue pipe and the electric meter cupboard beyond.  The oil boiler will the removed and replaced with a buffer tank and pump.
C1C392B0 7D68 406B 8EBF 42B786E5428F
JulianC
(@julianc)
Oil boiler removed.
FEB794BF 46DC 4A67 9DEA 412F344F63FB
Buffer tank in here now. Hydro box installed in garage. Daikin and Mixergy delivered. Old oil boiler sold on eBay.  Oil tank drained and removed. Good day 1. More photos to follow
Page 1 / 16
