Will heat pump heat hot water without increasing the temp in my home?
If you can post a photo of the screen you've managed to access, then we will find the right manual for you.
Yes, there are several possible control units by Mitsubishi...
... and installers may also choose to use others anyway.
@transparent Thank you for the link to the user manual (bookmarked it). I am not seeing all the icons on my screen. Not sure why.
The page in the instruction manual shows all possible icons and their position on screen.
It doesn't imply that all could be present simultaneously.
Some combinations are mutually exclusive, and couldn't ever appear together.
@ellyse Is it possible that some of the icons you are not seeing on your own display are for functions that you do not have (naming of parts again!)? Often if a function is not required as it has not been fitted, then the setup for it may be suppressed to reduce clutter and simplify the display. Regards, Toodles.
- 23 Forums
- 2,098 Topics
- 46.2 K Posts
- 236 Online
- 3,385 Members
I had a very similar problem with my valiant and it tur...
By JamesPa , 16 minutes ago
By Mars , 1 hour ago
@anca1808 I have just reviewed the whole thread. In s...
By JamesPa , 4 hours ago
By JamesPa , 15 hours ago
By Damon Blakemore , 21 hours ago
By downfield , 2 days ago
By Sune , 2 days ago
By Aventus Eco , 4 days ago
By Tim441 , 4 days ago
