Vaillant ASHP Weather Compensation with Octopus Cosy
Hi all,
I've been looking at tariffs with Octopus (currently on Fixed 12M) and the Octopus Compare app suggests it might be better for me to go onto the Cosy tariff.
I've got a Vaillant ASHP with weather compensation and it's been keeping the house at a pretty constant 20 degrees, with a heat curve of 0.65. If I did go onto Cosy I'd want to set it so the heat pump bought the temperature up a bit higher and then didn't go on at all between 4-7pm when the cost is high. Can that be done while still using weather compensation? I understood that if it's using weather compensation it ignores any other settings so any changes I made to the time control operation mode in the settings wouldn't make any difference, and there's not even a thermostat on the unit to know how how the house is.
Is that right, and is there anyway I can have the heat pump off between 4-7pm, or even at a setback temp?
In the Vaillant app go to Settings (the cog wheel icon) > Control > Heating > Weekly planner and put in a temperature below the setback value for the period 16:00 to 19:00.
Your Sensocomfort is the thermostat and it does work as one in partnership with the WC curve. In expanded mode it switches off once the room is above the value selected.
- 2,396 Topics
- 54.3 K Posts
- 123 Online
- 6,077 Members
The diagram below is a simplified view of the internals...
By Batpred , 4 hours ago
RE: Heat pump not reaching flow temperature
@davec Ive had a look at the screenshots. Lots of th...
By JamesPa , 4 hours ago
RE: Vaillant aroTherm not heating with many faults
When I had a series of apparently unrelated faults my i...
By JamesPa , 5 hours ago
RE: Considering MLCP (Multi-Layer Composite Pipe) for ASHP
OK, TBH I dont know enough about MLCP to comment with a...
By JamesPa , 8 hours ago
RE: Predicted Heat Loss from MCS calcs vs EPC vs actual
My gut feeling is that the heat pump is right sized. ...
By Tim441 , 8 hours ago
RE: Power outages and storms: A surprisingly good DNO experience
Agreed, which is no more nor less than a customer shoul...
By Majordennisbloodnok , 9 hours ago
@batpred In our case, 3 times each day when the Octopus...
By Toodles , 10 hours ago
Hi @sheriff-fatman Cycling at 5C and below is usuall...
By RobS , 10 hours ago
@batpred Here's the latest Fogstar ready built pack....
By Bash , 12 hours ago
@mike-patrick yes, even though the current system is ru...
By Tim441 , 12 hours ago
Solis confirmed that the S6 works with a single battery...
By Batpred , 12 hours ago
I am wondering if in any V2X, would the car battery eve...
By Batpred , 13 hours ago
Yes, by calculating it manually from the minute data, w...
By cathodeRay , 14 hours ago
Fan unit Making terrible noise HELP!!
One of a pair of fan units on an Earth Save Classic II ...
By GutoFfowc , 15 hours ago
OK. I think your system, which seems well designed, is...
By JamesPa , 16 hours ago
RE: Heatpunk Floor plan issues
It's usually the complete opposite... seldom that Safar...
RE: Fan is clipping ice build up from the front of unit.
@majordennisbloodnok I’ll not go there thanks! Toodles.
By Toodles , 1 day ago
RE: Running my new Nibe ASHP efficiently
I'm new to the forum. Did you get a reply to this last ...
By Mike @ Camelot , 1 day ago
@grantmethestrength MCS requirements for DHW capacity h...
