Vaillant Arotherm Plus
Vaillant Arotherm Plus or rather Vaillant Aro Horror plus nightmare
installation content: DHW cylinder, Hydraulic Station 97/6, MHT 150, VRC720, AI and VR71.
what a mistake to make, first day straight F.1100, then either runs DHW or heating but never together, happily passes all tests, even immersion test but after restart gives me F.1100. who from vaillant come up with that stupid idea? why would immersion heater blow up , isn't it easier to put a fuse , clever engineering or playing ? On top of it, pressure goes up / down whenever it feels like. what a piece if metall-plastic waste.
i should never ever buy germany made again, their time is vorbei.
- 2,118 Topics
- 46.6 K Posts
- 102 Online
- 4,523 Members
@jamespa i just want it right at the end of the day, th...
By AdamK , 4 hours ago
By downfield , 8 hours ago
By Toodles , 9 hours ago
FRV valves - can you mix and match
Great video again this week @editor, I am very interest...
By Grantmethestrength , 10 hours ago
By normpang , 2 days ago
By ASHP-BOBBA , 2 days ago
By Burtis , 6 days ago
By Old_Scientist , 7 days ago
By Lucia , 1 week ago
