At those times on the 6/7th Frost protection kicked in. The two flow temperatures are the starting and ending for the frost protection period. The duration was around 15minutes. Yes showing frost protection on the controller.
I was expecting it to only kick in when the outside temperature reached 4oC and then elevate the flow from 6 to 12oC.
258-DHW; apologies 258 is the heat pump cycle number and DHW for heating the hot water.
When i moved the outdoor sensor indoors , the number of frost protection cycles reduced. The heating came on as per the programme.
Im sorry but I really don't understand from what you have said how you are running your heat pump (for example how can WC work when the outdoor sensor is indoors, and that being the case how did the heating 'come on' as per the programme'? ). Its also going to be difficult to work out things based on what happened over 2 months ago and with the outdoor sensor indoors.
Can I suggest you
1. relocate your outdoor sensor outdoors
2. take screenshots of the settings governing the heating schedule, room influence mode and weather compensation
3. when the problem next occurs record:
what the heat pump should have been doing according to the program you had set up and why you think this
the indoor and outdoor and flow temperatures on the sensocomfort
the time of day and date.
With a fresh example and more data on how you are running your heat pump maybe it will make sense, currently I am sorry but it doesn't, at least not to me.
I apologise I cant be more helpful at present however its difficult to tell what is going on with the various changes to configuration and the moving of the outdoor sensor, particularly as the latter is so absolutely fundamental to the control of the unit all of the time not just for frost protection.
Much appreciated for your help and thoughts. I will keep a diary. Thank you again
It occurs to me, have you got a timed heating schedule and if so what is it. Can you tell me why the indoor temperature was so low in the records in the diary. Something isn't making sense about the whole setup.
Just to emphasize, the outdoor sensor isn't primarily for frost protection, it's part of the basic weather compensation control loop of the system. It really has to be outside.
Vaillant AroTherm Plus 7kW
8 months ago
Vaillant - Downstairs radiators not getting warm
1 year ago
1 year ago
1 year ago
1 year ago
- 564 Online
By JamesPa , 1 minute ago
By Mars , 54 minutes ago
By bobflux , 2 hours ago
By Renewables345 , 3 hours ago
By benson , 3 hours ago
By bobflux , 4 hours ago
By bobflux , 5 hours ago
By Jonatan , 10 hours ago
By Batpred , 17 hours ago
By Transparent , 20 hours ago
By bobflux , 21 hours ago
By Toodles , 23 hours ago
