Setting different temperatures throughout the day. Good idea for ASHP?
Hi,
Ive got a Salus RT510 thermostat which controls the rads. Should I set a a standrad temperatures (19 degrees for example) across all 6 programmes? Or is it best to have different temperatures across different times of day?
Thanks
The standard advice is to only vary settings by a maximum of 2C throughout the day e.g. 20C when you're at home, 18C overnight, and 19C during daytime but house is empty. HPs cannot raise house temperature at the same rate a gas boiler would.
Whether this is good advice is open to (much) debate. The answer will probably be "it depends".
Grant Aerona 3 10kW
as a general rule, in a moderate to well insulated house, keep variation as little as possible. But, other factors are always in play:
- do you want it warmer in the evening for lounging comfort?
- have a time of use electricity tariff?
If the weather compensation of the heat pump is perfectly configured i.e. the variation of the flow temperature against outside temperature exactly matches the heat loss of the house at all outside temperatures, then the indoor temperature will never vary. of course, no setup is perfect. some heat pumps have load compensation as well as weather, meaning they can boost / adapt their output if an internal temperature rise is requested.
- 388 Online
By Bash , 21 minutes ago
By Toodles , 30 minutes ago
By Majordennisbloodnok , 49 minutes ago
By benson , 54 minutes ago
By trebor12345 , 1 hour ago
By Travellingwave , 2 hours ago
By RobS , 3 hours ago
By Batpred , 4 hours ago
By Sheriff Fatman , 5 hours ago
By GC61 , 6 hours ago
By cathodeRay , 10 hours ago
By JamesPa , 21 hours ago
By Batpred , 22 hours ago
By DavidB , 1 day ago
By Slartibartfast , 1 day ago
