my understanding from reading the manuals is that when water law is active - you cannot select "indoor" mode on that screen.
if indoor is active you are telling the heat pump to adjust it's temperature based on the indoor thermostat rather than the outdoor weather
*as far as i understand it!*
@simonh I think I know what’s happening. I have water law enabled but the room temperature is controlled via the Samsung controller which is acting as a limiter at 22C. When it was mild it was turning off the HP before it started cycling now it rarely turns off the heat pump at all as the WC is limiting the room temperature.
@simonh I stumbled across this which relevant
https://community.openenergymonitor.org/t/i-want-to-punch-my-samsung-controller-fsv-2091/27143
Posted by: @simonhmy understanding from reading the manuals is that when water law is active - you cannot select "indoor" mode on that screen.
There are 2 main display options on your wired remote controller. In both displays the current flow temperature and room temperature are shown on the right hand side. On the left hand side of the display is a setting that you can adjust with the up and down arrow.
- If you are using an external thermostat (FSV 2091/2092 = 1-4), then the adjustable setting is the Offset that you can apply to your water law settings (+/- 5C)
- If you are using the internal Samsung thermostat in the wired remote controller (FSV 2091/2092 = 0 (Not use)), then the adjustable setting is the desired room temperature.
In both cases, the flow temperature is controlled by your water law settings ie weather compensation is in operation. You could argue that using an external thermostat is more versatile as not only can you set the desired room temperature limit, but you can also change the target flow temperature without going into service mode by simply changing the offset value. Whatever you choose, weather compensation will be operating.
There is another option - in service mode --> Indoor Zone Option --> Standard Temperature --> Water Outlet. This allows you to set the desired flow temperature directly and in this case there is no weather compensation. This isn't used much.
@mike-h Thanks for that clear explanation Mike. Very useful.
How to choose Towel Rails for an ASHP
2 days ago
Samsung problems
2 weeks ago
2 weeks ago
Sudden drop in COP
1 month ago
3 months ago
- 2,171 Topics
- 47.8 K Posts
- 37 Online
- 5,744 Members
@jamespa Thanks. Yeah any adjustments Ive made at pr...
By cliffhanger , 18 minutes ago
@jamespa pretty sure, unless the water pump makes a hum...
By AdamK , 31 minutes ago
I have been running mine in auto adapt since 2019 and i...
By Abernyte , 2 hours ago
Many of those tariffs are simple time of use tariffs, w...
By Temperature_Gradient , 12 hours ago
So far as I can tell designing for DT5, which is 'the n...
By JamesPa , 13 hours ago
By GrahamF , 2 days ago
By bontwoody , 2 days ago
By Scalextrix , 2 days ago
By cathodeRay , 3 days ago
By Paul G , 4 days ago
By JamesPa , 5 days ago
