rad size and efficiency
im going to have a Vaillant fitted and just see how it runs with the rads i have currently. how does having potentially undersized rads affect efficiency? or does it only affect comfort? assuming im controlling on weather comp?
It is just thermodynamics, the higher you move the flow temperature the more it will cost to run, existing radiators may need a higher flow temperature so the heat pump will cost more to run, your radiator upgrade, will usually be paid for in less than 2 heating seasons.
Posted by: @adamkwhat if i set the system so its controlling on flow temp only, surely it would then just be a case of seeing which rooms dont get to 20c and upgrade those?
Adia Thermal sort of advocate this approach and produce some hardware to aid the determination.
In many cases however it will be obvious that an upgrade is needed, best in my view to do the calculations up front. If any are marginal then you could adopt the suck it and see approach for those. You need an increase in area of a factor of 2 or more if you move from a system designed for a boiler at a flow temp of 70C to a system designed for a heat pump at 45C, but if you have added insulation since the original installation, or the rads were anyway oversized, some may be reusable (some of mine were)
- 2,783 Topics
- 65.6 K Posts
- 660 Online
- 7,187 Members
Excellent find, thanks for posting the link here.
By cathodeRay , 50 minutes ago
It's the reverse, the hybrids need less space. The back...
By Temperature_Gradient , 1 hour ago
By bobflux , 13 hours ago
All the 45° elbows required for getting the primaries i...
By Singlespeed , 15 hours ago
@papahuhu Likewise, the main ‘extra’ relates to TOU tar...
By Toodles , 20 hours ago
Thanks for the reference @jamespa I can't see any te...
By bobflux , 2 days ago
By Andris , 2 days ago
By Papahuhu , 3 days ago
By Batpred , 3 days ago
By Rob of York , 3 days ago
By downfield , 4 days ago
By Mars , 5 days ago
By ian33a , 5 days ago
