Pressure Drop in primary circuit
Good morning !
I am writing this as I am dealing with the Samsung help line !
Two days ago I posted about losing pressure in my heating systems primary circuit.
Many thanks To James for replying!
Since then I have had the system turned off . After the initiall cool down of the system I checked all pressures and topped up as required.
I deliberately had the two circuits at different pressures .
Over night there has been a slight drop in pressure (1 to 2 psi) evenly in both circuits this I think is down to residual cooling.
Given that the system lost its Pressure over night when operating, would I be right in thinking the fault lies in the outside unit ?
Given that it has no warranty. Can and is it worth repairing these things ?
Are there people who would take it on ?
If I have to replace the unit will the wiring and pipes be of the same standard ?
I know It is a big ask, but my faith in tradesmen is very low , I have a self build and have learnt that I can live with my own mistakes, but find it hard to come to terms with paying other people, to muck it up or not provide support .
Many regards
Alistair
P.s heating not on the Samsung phone options.
I have just been given a diferent number from the one on my paper work 0330 7262677 . I am going in !
Hi Alistair. I’m not an engineer but it sounds as if your analysis is correct to me. Perhaps others will be able to confirm.
A replacement like for like should be a straight swap. I’ve fitted my own Samsung if that’s the route you want to take.
Whoo hoo A number that worked , option 5 !
An engineer is going to call me back !!
Nick from Samsung has called me back .
He has said that the system has had major trauma, and possibly for a long term, due to failure of the pressure vessel , and that it may take a while to expell all the air in the primary circuit !
Will keep the fill loop attached and top it up as needed for a week , and then report back !
I will hope for the best, and admit that this help has quelled some of my cynacism ! Thanks Nick !
If only I had recieved similar attention from my service / installers !
Thankyou to all
Alistair
- 22 Forums
- 2,088 Topics
- 45.8 K Posts
- 69 Online
- 3,374 Members
RE: Feasible solutions to expand existing Sunsynk battery capacity
@sheriff-fatman Good luck with the heat pump installati...
By ChandyKris , 8 minutes ago
Just to briefly update things, we now have a confirmed ...
By Sheriff Fatman , 47 minutes ago
Having made some enquiries locally I have found a compa...
By Morgan , 1 hour ago
Sorry to hear about your problems, which your installer...
By JamesPa , 2 hours ago
RE: I don't need any heating in the summer. How do I turn my Samsung heat pump off?
Thats great Someone else is struggling with this in a...
I guess your installer set it up to reheat continuously...
By JamesPa , 3 hours ago
RE: Plate heat exchanger considerations
@jamespa I don't understand any point in an air test, i...
By Scalextrix , 4 hours ago
@bart Best of luck moving forward, I look forward to he...
By ASHP-BOBBA , 1 day ago
By Morgan , 1 day ago
RE: Ecodan EMP2 kit - is it any good?
Please note: heat meter accuracy at 95+% is as long as ...
By ASHP-BOBBA , 2 days ago
RE: Air Changes per Hour - ACH and the MCS requirement
@jamespa I love going on the tools, I did it yesterday,...
RE: Flow Rate & Low Loss Headers
Houses with reasonably low loss aren't going to require...
If it's running on WC then at night it's quite likely t...
@majordennisbloodnok That’s OK as long as the ‘Terminol...
@aaron All features were in place for the last several ...
By AF1 , 3 days ago
RE: To relocate or add extra PV panels..advice required
The situation you are currently experiencing is represe...
By apollogrid , 3 days ago
RE: Remaining hot water/hot water flow meter
@lakey Hi, I had a quick read through and wanted to see...
By ASHP-BOBBA , 4 days ago
RE: I worry I've messed my Samsung settings up somehow
@ecobaker I missed this, sorry So 3031 was set to...
By Joshua , 4 days ago
