How I Negotiated a Better Deal on My Heat Pump Installation with Octopus Energy
Posted by: @njt...
Unfortunately Octopus won't fit it on the heat pump install, and Homely say the only sell to installers, so there's the problem.
Not sure if there's a bit of talking at cross purposes going on. You appear to be interpreting that as "Homely will only supply their box to whoever installs your heat pump". My interpretation is "Homely kit needs to be installed by someone professional, so they will only supply to businesses registered as Homely installers".
If I'm right, there would still be no problem since you could get the kit installed after the fact. In practice, I can't see why that would be a problem either since the only physical fun and games is with a bit of modbus wiring and that's not would need to be done when the heat pump is commissioned.
@majordennisbloodnok Installation involves connecting (on the Daikin range anyway) two wires to P1 and P2 within the existing control box / or straight to the heat pump connections. The modbus connects to the Homely controller and there are some switches to be toggled in the modbus itself. Homely provide the details of switch positions and the PSU’s to power the Homely and the modbus itself. There is a configuration programme which you initiate via their app and after some 30 minutes, Homely will start to take over all the control. The modbus I have is a D. Comm unit. Regards, Toodles.
Posted by: @toodles@majordennisbloodnok Installation involves connecting (on the Daikin range anyway) two wires to P1 and P2 within the existing control box / or straight to the heat pump connections. The modbus connects to the Homely controller and there are some switches to be toggled in the modbus itself. Homely provide the details of switch positions and the PSU’s to power the Homely and the modbus itself. There is a configuration programme which you initiate via their app and after some 30 minutes, Homely will start to take over all the control. The modbus I have is a D. Comm unit. Regards, Toodles.
Precisely. Thanks, @toodles, for confirming.
Making use of a physical modbus connection is not unique to Homely and is just an add-on bit of config that can be done at any time after the heat pump's commissioning. As long as @njt can get Homely to put an installer in touch then I see no issues whatever with their kit being installed completely independently from Octopus' work.
Posted by: @njtOh, and they wouldn't entertain doing a system design less then 50 Deg, even though I'd read somewhere someone got a 45 Deg design off them
@NJT, same here with my experience. 50degC design, which at the time I didn't query. But the same set up is now set to 45degC max, and most of the time sits between 35 and 40degC. 50degC does get rather thirsty on the power consumption, but an EPC B home probably won't require it if you run low and slow with all day space heating.
And one more thing, my Homely was a retrofit job as the firmware for the Daikin had not been created at time of installation; I had a NeoAir stat just set several degrees higher than required at first and used the heat pump’s parameters to control the heating comfortably. (I’ll own up to some degree of tweaking during this period though 😉) Regards, Toodles.
Thanks.
I'm just waiting for a date now for install, I signed last week.
I'm hoping for what they told me, 4 to 6 weeks. Definitely don't want to be installing winter time.
I'd rather have some time before it gets really cold to get used to everything.
Posted by: @allyfishbut an EPC B home probably won't require it
House heat required or EPC rating, is not what defines flow temperature, it's related to radiator size and flow temperature and the combined output in kW.
A bigger heat demand, at the same flow temperature, just requires bigger radiators. A smaller heat demand just gets smaller radiators.
If you design a system for a flow temp of 50, it just means you can get away with smaller radiators instead of big one suitable for the correct heatput at a lower flow temperature.
All heat pumps should be run low and slow. Trouble is when systems are designed for 50 Deg flow temp CoP is poor, doesn't matter is it's an EPC A or F, it's just rubbish.
- 2,505 Topics
- 58.1 K Posts
- 271 Online
- 6,237 Members
There are very few Type-B RCBO units. I certainly can...
By Transparent , 5 minutes ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
Remember that the house continues to lose energy when t...
By JamesPa , 7 minutes ago
@editor your opening statement on the thread states tha...
By Gmuzz , 21 minutes ago
RE: Knock on effective of balancing radiators
@bash If you find that you cant get a fine enough ad...
By JamesPa , 23 minutes ago
@transparent Some background 🙂 As you know I'm well up...
By dr_dongle , 44 minutes ago
@travellingwave, thanks for the post and kind words abo...
By Mars , 3 hours ago
@editor I'd missed that, and it's a very good response ...
RE: New Solar, Batteries, Air Source and Under Floor Heating advice please
In a word don't, or at least think VERY hard before doi...
By JamesPa , 4 hours ago
There has been quite a bit of discussion (mostly on OEM...
By MartinRobinson , 4 hours ago
@kev1964-irl At the outset just to say I am not a plumb...
By GC61 , 5 hours ago
@benson My system is a "simple" one: no DHW, no defrost...
By Tasos , 5 hours ago
@af1 My EPC rating jumped from E to C after installatio...
By dr_dongle , 7 hours ago
Hello fellow Daikin owner, my installer retro-fitted my...
By Toodles , 8 hours ago
@odd_lion the minimum MCS requirement is 2.8. I don't...
By benson , 8 hours ago
RE: Advice on potential HW Cylinder size
I think the comment about heating from cold is quicker ...
By sjcsystems , 18 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Hi You can get a stethoscope for less than 10€ on Ama...
By bobflux , 18 hours ago
Your DT is to low, you do not have enough heat exchange...
By ASHP-BOBBA , 21 hours ago
I am aware. But is your chart direct from a Pace BMS ap...
By Batpred , 21 hours ago
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simila...
@painter26 — good idea. Please do let us know what he s...
By cathodeRay , 22 hours ago
@robs — thank you for your as ever valuable comments. T...
By cathodeRay , 23 hours ago
Yes, but I need to reopen the battery box.. I just noti...
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
If your heat loss is only 4kW and the pipes leaving the...
