Octopus Cosy 6 installation (fan boy video)
@majordennisbloodnok Timing Dear Boy, …Timing.
I can give you some details on a few things - like survey, order process, the changes made during that process, some customisations and then the install, commissioning, support and finally the remedial work to get me happy
Yesterday my installers told me the designers have already upgraded the Cosy 6 software to offer more 'controllability' (weather compensation and so on) for those who want to go beyond plug and play. Plus, it's likely they will continue to do this, which is great.
@wreckguru Just skim read - 1 typo - Blurb = Bulb? 😁 Otherwise great - could you possibly add your kwh use since installation?
But @editor is the gaffer so he'll do a proper edit and rejig. 😉
(First time I've seen the back of a Cosy - never imagined it was flat). 🙂
Posted by: @lucia@wreckguru Just skim read - 1 typo - Blurb = Bulb? 😁 Otherwise great - could you possibly add your kwh use since installation?
Thanks, @lucia; you beat me to it.
@wreckguru thanks for sharing. I’ll give this a solid edit in the days ahead, and post on the site. Hopefully it’ll be up before the weekend.
- 22 Forums
- 2,090 Topics
- 46.1 K Posts
- 13 Online
- 3,383 Members
That outside pipework would concern me. Surely rigid se...
By benson , 7 hours ago
By downfield , 10 hours ago
Sadly I fear that they may well be right to do so. ...
By JamesPa , 12 hours ago
By ASHP-BOBBA , 1 day ago
By Sheriff Fatman , 1 day ago
By HarriUp , 2 days ago
What you run the cable through will affect its current ...
My advice is reject unless they will delete the buffer ...
By Old_Scientist , 4 days ago
By JamesPa , 5 days ago
