Octopus Cosy 6 installation (fan boy video)
Here's the first Octopus Cosy 6 YouTube installation video - I'm disappointed - the lack of questions or critical reasoning is sad to see.
Nicholas, the homeowner, managed to conjure up TJ, the Octopus heat pump big boss, which makes me question the claim that he paid for the installation - the softball questions smack of a PR agency...
TJ is the guy I had a bit of a to and fro with on Twitter - when I put it to him that Octopus using 50º design temps was offloading running costs onto customers in exchange for quick hit installs. It's interesting to me, the way he phrased his comment on this in the video which was filmed shortly after our wee debate - I used British Gas as an example to him in our discussion and he knows I'm a journalist. [🤔]
The Cosy:
Designed by a pretty reputable guy but I suspect the brief is plug-and-and-play for Mr & Mrs Jo Public who won't want to think about weather compensation curves or flow rates. That's not an entirely bad logic of course, it's a market that must be addressed and smart-arsed Octopus got in first.
It's plastic! 🤦🏻♀️
There's all the obvious criticisms of it being just plain ugly, likely to fill up with dead leaves and crap, or snow. The sensor pads in rooms (the miles of trunking on that guy's install (why the f*** did he put it outside his garden), the overselling of the refrigerant being greener and crucially, all that kit bundled inside the case.... but no one questions the data harvesting!
The Cosy can not only be 'updated' by Octopus, it can be physically run - ideally to fit smart tariff timings - but potentially also for load shifting during grid overloading times.
Meanwhile, Octopus get to harvest all that juicy data and link it to smart meter data - there's gold in them thar hills and no one asks any of the awkward questions about data privacy and rights. 💰
Oh, my days. 🙈
Like most of the comments on YouTube about the video, I can't believe where it's installed.
Surely he could have installed it inside his garden other side of the wall.
It's just asking to be damaged, or worse stolen, along with the metres and metres of copper pipework.
Surely it is there as an advertisement for Octo. If it gets nicked TJ will probably bring another, again no charge. 🤔
Daikin 6Kw ASHP.
MG4 EV
I think @lucia raises a serious point about Kraken data harvesting. I saw on another of Nicholas's videos he talks of the EV charging Tariff Intelligent Go whereby the car has communication with Octo using the api and a sim in the car which has some control of it's functions (Roboapocalypse?). Now I do not have any expertise in these things but it seems another example of Octo harvesting data. Are they trying to be the "Google" of Energy?
Daikin 6Kw ASHP.
MG4 EV
Looks like a gents urinal at a music festival. Only a matter of time until someone pi$$es into it.
@njt In one of his videos, Nicholas remarks that he didn’t want any units spoiling the space in his garden. 🙄 ! Regards, Toodles.
Posted by: @jancoldNow I do not have any expertise in these things but it seems another example of Octo harvesting data. Are they trying to be the "Google" of Energy?
Could well be a data harvesting example or could the Sim in the car be a simple protocol converter to enable the Octopus Kraken system to talk to the bespoke car software to control the EV charging?
Bivalent system containing:
Posted by: @allyfishLooks like a gents urinal at a music festival. Only a matter of time until someone pi$$es into it.
I’m aware that usually you have to have a DHW cylinder with a heat pump, but I invested in a Sunamp heat battery to soak up my solar as I had no facility for immersion in my old Hot water cylinder( heated by an oil burner) So my question is : is it mandatory to have cylinder? Or is it straight forward to run an ASHP system purely for heating? As my current oil fired ssystem does?
I know that there are grant stipulations about having to heat both water and space with the HO but that’s a daft rule as all
my hot water in summer etc is free via solar and even in Winter the 2kwh from the panels just about covers the power needed to top up the Sunamp daily! In summer the 4kw array and do as much as23 kWh in a day.
our House is Victorian but has EPC B ( Solar PV, 10kw heat and electric batteries, with newly installed £10k of internal insulation , 75% paid by EST)
- 2,113 Topics
- 46.4 K Posts
- 35 Online
- 3,410 Members
By Transparent , 6 hours ago
By JamesPa , 7 hours ago
By Mars , 19 hours ago
By Prunus , 3 days ago
By JamesPa , 5 days ago
By Transparent , 6 days ago
By Wh0am3ye , 6 days ago
By TechnoGeek , 1 week ago
By seatonian , 1 week ago
