Need help working out base for Vaillant 7kw
Need help with a diagram of what’s need for a base for a 7kw Vaillant. Also what the optimal gap to leave between the wall of the house and corner of the house? Nothing in front or either side of the HP apart from a soil vent pipe that runs up the back of the property.
also where does the condensate go? Don’t have a gully at the back of the house.
having to ask all this as installer is 70 miles away and can only come and fit for 3 days.
- 22 Forums
- 2,014 Topics
- 43.9 K Posts
- 43 Online
- 3,187 Members
Need help with a diagram of what’s need for a base for ...
By AdamK , 7 hours ago
RE: Is my Samsung heat pump working too well?
I might have missed this earlier in the topic, but what...
By guthrie , 9 hours ago
RE: Grant Aerona fine tuning advice needed
I am currently learning as much as possible about our s...
By Grantmethestrength , 11 hours ago
RE: How many compressor starts per year
Just checked mine. 543 starts from mid November to now...
By JamesPa , 11 hours ago
RE: What happens when the outside temperature exceeds the upper WC point?
@gary We've got the FTC7, maybe older controllers didn'...
By RobS , 11 hours ago
Manufacturer: Grant Model: Aerona3 13kW Type: ASHP ...
By Grantmethestrength , 13 hours ago
The Good, the Bad and the Ugly. The Good: First of ...
By Grantmethestrength , 14 hours ago
RE: Samsung Joule Wriggling Out Of Their Warranty
@rickk54 I've just been looking into warranties and cam...
By Mars , 17 hours ago
RE: A question about battery life
Agreed. Perhaps that was a bit overdramatic on my part....
The Big Heat Pump Survey 2025 – We Need Your Input
If you haven't already seen it, we’re running The Big H...
By Mars , 18 hours ago
Certification for heat pump installation
This week, Dept of Energy Security and Net Zero have re...
By Transparent , 20 hours ago
@heacol do you have any info to assist potatoman with t...
RE: Would You Find Value in a Premium Installer-Supported Forum?
I’ve been working on this behind the scenes as well. We...
RE: Are Homeowners Being Silenced Over Faulty Heat Pumps?
@ectoplasmosis I’ve never had an issue naming and shami...
RE: Grant Aerona3 - Home Assistant control via Modbus
This is true, but I about learning about agentic AI and...
RE: Is it KISS or constant – weather compensation vs. set flow temperature?
I had to laugh at this as I do exactly the same thing, ...
@eliuccio there are some very high level arguments in t...
By Judith , 2 days ago
That's fine @irmartini and @editorbut let's keep this i...
So just for completeness here is may last update on thi...
By bontwoody , 2 days ago
Most Active This Week
# | Name | kWhs |
1 | Mars | 487 |
2 | JamesPa | 226 |
3 | bontwoody | 175 |
4 | Pooneil | 158 |
5 | Transparent | 136 |
6 | Majordennisbloodnok | 135 |
7 | ASHP-BOBBA | 116 |
8 | Heatgeek | 111 |
9 | cathodeRay | 110 |
10 | Toodles | 108 |
