Name and shame heat pump installers that have done shoddy work
Thanks, yes I'll be interested too!
@witchcraft and @editor - congratulations to both of you on getting this out there.
I don't know how this would stand legally, but it would be useful to know the names of the people involved with Greenfoot, just in case they set up business again under a different name.
@witchcraft, I got a reply from Ian today, MD of MCS, relating to this issue and he’s asking for your post code and address so that he can look into it. If you’re comfortable sharing this with him, please DM me, and I’ll happily send it to him. Let me know.
@witchcraft, they’ve gone all gone deadly quiet. Several follow ups, the latest on Monday, and not even a reply. I’ll keep the pressure on to get a reply.
- 46 Online
@jamespa Thanks. Yes, its a bit sad so many of these jo...
By ASHP-BOBBA , 4 minutes ago
I managed to find a perfectly good new but 'last years ...
By cathodeRay , 11 minutes ago
By dgclimatecontrol , 2 hours ago
My heating isn't 'ON' yet, although it is firing up in ...
By Morgan , 2 hours ago
@damonc If the heat pump controller is in a suitable ar...
By HCas , 3 hours ago
If that's the case then you are right to be sceptical, ...
By JamesPa , 6 hours ago
By Lucia , 9 hours ago
By ASHP-BOBBA , 20 hours ago
By Tim441 , 1 day ago
By Transparent , 1 day ago
By HCas , 1 day ago
By jamespetts , 1 day ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 3 days ago
