@batalto @derek thanks guys.
@morgan Yes that is correct, I would suggest that TRV valves are only put on the bedroom radiators, all the rest of the radiators have lockshields only. The temperature controller/sensor must be in a common area. That is how we do it. What unit are you getting installed?
Posted by: @heacol@morgan Yes that is correct, I would suggest that TRV valves are only put on the bedroom radiators, all the rest of the radiators have lockshields only. The temperature controller/sensor must be in a common area. That is how we do it. What unit are you getting installed?
LG 11.2 Ecodan Ultra Quiet. FTC Controller. Does that answer the question?
Posted by: @heacol@morgan Yes, make sure you get the RF room sensor.
@heacol
RF room sensor? Lost. Help appreciated.
@heacol My installer is going with a Neostat wifi. Comments?
@morgan Your choice, The Neostat is a complicated on-off thermostat that can be only programmed by the idiot who designed it. Whenever I come across any products by that manufacturer, they go in the bin, to the delight of the poor person whom it was foisted upon.
If you are determined to have an on-off thermostat, this will give better performance as you can actually operate it without the 20 page manual. The 2 thermostats are exactly the same thing. They work like a light switch.
https://www.screwfix.com/p/flomasta-emp912mt-mechanical-room-thermostat/132jk
@heacol Oh well that lifted my day lol. He suggested the wifi neostat as it can be moved around to find our ideal site.
@morgan The Mitsubishi unit is also Wi-Fi, but it talks intelligently to the controller. Same thing, but it actually works. The Neostat will add at least 30% but probably 80% to your electricity bill.
@heacol Very cheery news! They look like they do the same thing to me but what do I know!
@morgan, you could not be further from the truth, they do not do the same thing. The Mitsubushi unit talks to the heat pump, informing it of the actual internal temperature and allows the heat pump to supply the correct ammount of energy to your property to maintain the internal temperature at the most efficient rate.
The Neostat switches the heat pump on and off, and does nothing else, like using the ignition key in a car to regulate the speed.
- 2,765 Topics
- 65.1 K Posts
- 1,885 Online
- 7,169 Members
By bobflux , 2 hours ago
By cathodeRay , 4 hours ago
RE: Vaillant Arotherm Plus 7KW need a service on it
booked it with Vaillant. will use them until i can find...
By AdamK , 5 hours ago
We have electric underfloor heating in our reasonably l...
By Bash , 8 hours ago
@jamespa This was exactly what I did in the...
By Bash , 9 hours ago
I have seen it stated that the declared calorific value...
By JamesPa , 10 hours ago
Here's my heat pump running with a steady mildish 'OAT'...
By cathodeRay , 10 hours ago
RE: Two heating zones to one zone
@transparent Many thanks. The garage is fairly well ...
By Profzarkov , 1 day ago
RE: Vaillant Aurotherm - Heater Wire Position
Ah, good point. I need to check if this was installed i...
@batpred thanks for getting a copy. Appreciate the supp...
We have a 6.56kW solar PV system (16x 410W panels) inst...
By Rob of York , 2 days ago
RE: Where heat loss surveys seem to go against practical reality
@cathoderay @jamespa I've managed to get some nice re...
By Rob of York , 3 days ago
RE: 7kW EV Charger Options Advice
Doh, not sure that I was thinking straight there, less ...
By Rusty , 3 days ago
Thank you @trebor12345
By rgabor , 3 days ago
