MCS heat loss calcs and Catch 22
Posted by: @kev-mIMO the majority of houses in the UK are not special cases and a good, experienced ASHP heating engineer should be able to look at a house, ask a few questions and give an adequate estimate of sizing cost that is good enough for an initial quote.
Definitely. Start by asking for the current annual consumption (or better still smart meter readings) and heating pattern. That will give an estimate which will, in many cases, be better than the current method and, imho, should in every case be used to sense check the current method and in some cases should be used instead of the current method.
- 54 Online
By jamespetts , 19 seconds ago
I do not think that a 300l cylinder is too big for a tw...
By jamespetts , 35 minutes ago
By Scalextrix , 17 hours ago
By HCas , 19 hours ago
By GrahamF , 22 hours ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
By bontwoody , 4 days ago
By Alex , 4 days ago
By GrahamF , 4 days ago
