Maintaining thermal mass vs starting heating later in season?
Has anyone considered the difference strategies between these:
1. Start heating soon, so as to maintain the temperature of the thick stone walls, etc we have, so we are only trickling heat into the building. However it would mean starting the heating maybe 2-4 weeks earlier in the season
2. Keeping the heating off, then having a few days where the HP has to work quite hard to bring the building back up to temperature. Trying to heat a room with cold stone walls is hard. But it means keeping the heating off for longer
To give context our building is old, and while insulated, there's still a lot of exposed stonework (until our retrofit is complete).
Outside temp here is about 16c now, 12-13c overnight. The house is maintaining about 19-20c with windows open, no heating. So the stone is doing it's work!
I suppose internal brickwork or brickwork that is insulated on the outside will stay approximately at your internal temp throughout winter. Uninsulated brickwork will settle into being 20C on the inside and coldish on the outside over time.
As I see it, adding heat before the inside gets below your set point won't give any benefit. If it were me I would turn on the heating as soon as the internal temp drops below the set point, but not before. 🙂
- 2,396 Topics
- 54.3 K Posts
- 276 Online
- 6,077 Members
Great point, one of the key ones in my chat with Octopu...
By Batpred , 7 hours ago
Definitely and professionals sometimes miss it. I had...
@batpred Well, I'm running the eBus interface and integ...
By dr_dongle , 9 hours ago
That´s an interesting point. The combi that we have is ...
By Batpred , 9 hours ago
Hi @green_fox As a we have a PUZ-WM80VAA with FTC7 (...
By RobS , 10 hours ago
Let me point out that there are many Chinese suppliers ...
By Transparent , 12 hours ago
@jamespa Thanks very much for this, and for mentioning ...
By anotherdaveuk , 12 hours ago
@majordennisbloodnok — The Two Ronnies Mastermind sketc...
By cathodeRay , 12 hours ago
The Regulations specify the export limits in Amps. If...
@wally Hope your issues are sorted out soon. We have ...
By ChandyKris , 12 hours ago
Just realised that this image of the cylinder cupboard ...
By Sheriff Fatman , 16 hours ago
Two thoughts: 1: Let's ask @david-s if Primary Pro in...
By Transparent , 16 hours ago
In the diagram below, I describe my understanding of th...
By Batpred , 17 hours ago
I need to have a look out for it. I know IBM feeds some...
RE: Heat pump not reaching flow temperature
is the house warm enough?
By davidnolan22 , 22 hours ago
RE: Daikin Atherma ASHP Cycling 6 Times an Hour?
Thanks for your reply. Yes that's a good idea to try a...
By John Marshall , 23 hours ago
RE: Hot water heating in parallel with space heating
An external heat exchanger would need a pump which woul...
By bontwoody , 23 hours ago
RE: Gen 6 Samsung ASHP losing 20C of DHW in 60 min directly after generation
@ecobaker Thanks for this. I've had it in both slots. ...
By andbeck , 1 day ago
RE: Air source heat pump circuit not operational
Welcome to the forums. If the thermostat shows it’s c...
