LG Therma, Controller settings help needed
Im in the process of helping a friend make the best of the heat pump they had installed 3 years ago. The company no longer exist and their bills are high. (How many times have we heard that!)
They appear to have a water cylinder with integrated buffer vessel.
What I would like to do first is check they are running on weather compensation and adjust their settings to get the maximum efficiency. I would also like to perhaps improve DHW efficient too.
Ive managed to get into the installer settings but do not have experience with LG I just wanted to check what I understand.
I will attach images but summarise the settings below:
Room Heating
Heating Temp setting <Outlet>
Air Heating set Temp <16><30>
Water Heating set Temp <20><65>
Hysteresis Heating Water <-2><2>
Hysteresis Room Air (Heating) <-0.5><1.5>
Pump Setting in Heating <Time setting> <3 On><3 Off>
Seasonal Auto Temp
Mode <heat>
Outdoor Temp <-10><18> Graphical display
Target Temp <-10 (50C)><18 (40C)> Graphical display
Water Heating?
Select Temp Sensor <Water><Remote Control>
Use Heating Tank Heater <Use><Cycle><30>
From my photos, im not absolutely sure I have things in the right section, but I will explain what I think Im seeing.
The 'Season Auto Temp' is saying that Weather Compensation is active with a flow temperature of 50C at -10 OAT and 40C at 18 OAT. Given they have UFH with a large area and thick slab I think these figures could be dropped substantially.
Im not sure what the 'Room Heating' and 'Water Heating' are telling me but I think given they are on Octopus Cosy I would like to set specific water heating time slots and maybe disable the immersion for legionella control.
Given the UFH and radiators have individual on/off valves, Im not sure how this is managed in the controller.
Thanks for any help in advance.
10kWh DC coupled battery
I know little about the various LG controls and reading the screens is of limited assistance with my eyesight however…
I think you have told us sufficient when you mention the WC settings. I suspect that the 50 @ -10 might be reduced a little (initially, perhaps 5 degrees but the 40 @ +18 sounds very high. I would suggest that you might safely drop that to 30 @ + 18 as a starting point. Further reduction might well be possible once you establish the change this makes. Regards, Toodles.
@toodles Thanks, my thoughts exactly although temperatures here rarely drop below zero for long. What Im not sure about is where to change the settings but im watching some youtube videos to try and get a bit more info.
Only just saw this. There is an excellent Facebook LG ASHP user group. Includes a document with detailed weather compensation settings
https://www.facebook.com/groups/716683532924964/?ref=share
LG Therma V 16kw ASHP
Underfloor heating + Rads
8.7kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
- 2,792 Topics
- 66 K Posts
- 2,563 Online
- 7,197 Members
I think Heat Geek have done an amazing job on their bra...
By Tomtheheatingengineer , 10 hours ago
RE: HeatGeek vs Octopus surveys: puzzling disparity - any ideas why?
I have just had 3 heat loss surveys, one by heat geek o...
By David , 10 hours ago
I think that's the key question. After all inverter uni...
By Prunus , 11 hours ago
As of October 1st they need specific qualifications to ...
By EtchedPixels , 12 hours ago
A unit which uses water to transfer the heat/chill from...
By Temperature_Gradient , 13 hours ago
With regards to the BUS grant raid, I gave it more thou...
By ASHP-BOBBA , 13 hours ago
The whole system seems to work on the basis of...
By ian33a , 13 hours ago
Good plan. If you can get half hourly meter readings a...
By JamesPa , 18 hours ago
@editor Most certainly. The heat pump was an ideal s...
By Abernyte , 18 hours ago
Although regulations may well vary from country to coun...
By Majordennisbloodnok , 19 hours ago
Yep I caught our slow leak from a £100 bill rise 8)
By EtchedPixels , 19 hours ago
RE: Do You Need a Buffer Tank or Low Loss Header for Underfloor Heating in a Large Property?
@jamespa in some cases, failing the Turing test might b...
By GrahamF , 22 hours ago
@energystoragetech The heat capacity of some...
By JamesPa , 24 hours ago
RE: tepeo ZEB UK Support & Info Thread
Sorry you are correct, I was remembering figures from t...
