I'm new to all this. Am I setting off on the right foot?
Good spot- I put kW then copied them. I suppose they amalgamated it with J/s
Thanks, both. I knew that I had to validate getting the energy to the radiators but haven't yet set about analysing it. Presently, the boiler plumbing is 28mm which splits to 22mm for the two CH and DHW valves. There is just over 2m of 22mm before splitting into two primaries, each of which supplies one 'wing' of the L-shaped property. If necessary, it would be relatively straight-forward to replace this section with 28mm when replacing the DHW cylinder. All branches from the primaries are 15mm, transitioning to 10mm for vertical drops in the walls to downstairs radiators. I am confident that there is only one radiator on each 10mm section but I need to investigate what is on each 15mm branch. There are 15 radiators in all and suspect that 12 will need replacing. The Kitchen/Diner has two tall 'Designer' radiators and I suspect that either a 3rd will need adding or the heating supplementing with an A-A heat pump, which would have the additional benefit of providing cooling in the summer months. Given the expense that all this will entail, should I consider a less efficient high temperature heat pump as an option?
- 2,396 Topics
- 54.3 K Posts
- 342 Online
- 6,077 Members
RE: Vaillant aroTherm not heating with many faults
@anon67 when was it last serviced? 1st thing to do is s...
By ASHP-BOBBA , 2 minutes ago
Hello all,I'm new to the forum. Just had an octopus cos...
By razz , 8 minutes ago
RE: Predicted Heat Loss & Needs from MCS calcs vs EPC vs actual
Not sure I entirely agree, @benson. In his last post, @...
By Majordennisbloodnok , 17 minutes ago
Excellent graphics and description Rob…. But to my mind...
By SUNandAIR , 40 minutes ago
RE: Heatpunk Floor plan issues
Now I understand why heat geek and others charge for th...
By jamiejones85 , 2 hours ago
The diagram below is a simplified view of the internals...
By Batpred , 12 hours ago
RE: Heat pump not reaching flow temperature
@davec Ive had a look at the screenshots. Lots of th...
By JamesPa , 12 hours ago
RE: Considering MLCP (Multi-Layer Composite Pipe) for ASHP
OK, TBH I dont know enough about MLCP to comment with a...
By JamesPa , 15 hours ago
RE: Power outages and storms: A surprisingly good DNO experience
Agreed, which is no more nor less than a customer shoul...
By Majordennisbloodnok , 17 hours ago
@batpred In our case, 3 times each day when the Octopus...
By Toodles , 17 hours ago
Hi @sheriff-fatman Cycling at 5C and below is usuall...
By RobS , 18 hours ago
@batpred Here's the latest Fogstar ready built pack....
By Bash , 19 hours ago
@mike-patrick yes, even though the current system is ru...
By Tim441 , 19 hours ago
Solis confirmed that the S6 works with a single battery...
By Batpred , 20 hours ago
I am wondering if in any V2X, would the car battery eve...
By Batpred , 21 hours ago
Fan unit Making terrible noise HELP!!
One of a pair of fan units on an Earth Save Classic II ...
By GutoFfowc , 22 hours ago
OK. I think your system, which seems well designed, is...
RE: Fan is clipping ice build up from the front of unit.
@majordennisbloodnok I’ll not go there thanks! Toodles.
RE: Running my new Nibe ASHP efficiently
I'm new to the forum. Did you get a reply to this last ...
By Mike @ Camelot , 2 days ago
