How to set the warm end of the weather compensation curve when it's not warm
There was thread somewhere recently, which I can't find now, where someone had a DHW pump that was running continuously. That would be annoying but not a hindrance if the HW is always getting topped up after 10° drops, but if something like that was happening in your system after the end of a heating cycle then you would just end up with a tank of tepid water following a sizeable draw-off. It was easily fixed as the pump wiring had been connected to the wrong socket in the controller. It is worth checking if the pump is running when it should be off – just feeling if it is vibrating should be enough.
210l Mitsubishi solar tank
Solar thermal
3.94kW of PV
- 39 Online
It was 7C here last night and the Ecodan kicked in at 0...
By Abernyte , 9 minutes ago
COP is not the only measure of efficiency
When I had my heat pump installed last year, the instal...
By jamespetts , 20 minutes ago
By HCas , 38 minutes ago
@jamespetts I agree it's extremely hard to calculate RO...
By Tim441 , 58 minutes ago
By jamespetts , 1 hour ago
By jamespetts , 2 hours ago
I do not think that a 300l cylinder is too big for a tw...
By HCas , 20 hours ago
By HCas , 21 hours ago
By GrahamF , 24 hours ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
By bontwoody , 4 days ago
