Help me keep the faith with my air source heat pump installation
UPDATE.
theyve been and sorted the flexis today by moving them so they are vertical, about the only way they could do it without moving the heat pump, so that’s sorted. Also said they will send the sparks to replace the rcd/mcb’s. So hopefully near the end of the pain, well at least until winter when I find out which rads I need to change😀.
Posted by: @adamkUPDATE.
Great news
I edited my previous post (probably after you read it) as the Vaillant manual, at least to my reading and in the version I have, actually permits the arrangement you have. However if they are going to sort it anyway that resolves the matter.
I’m back,
well Vaillant called me a week ago at which point I explained I was still waiting for the electrical works to be rectified. They said they would email them. A week later and just over 4 weeks since they visited last no contact from them. I’ve since commented on a vid about a heat pump install stating the heat geek logo doesn’t guarantee a good install. Interestingly heat geek replied asking if I meant they weren’t heat geek. I stated no they are. Then silence. I’ve emailed heat geek to request I talk to someone who replied cause they are saying even though I didn’t go through heat geek they expect there installers to do stuff properly.
@adamk, interesting point. I’ve not focused much on Heat Geek installations because, compared to other schemes and organisations, we haven’t seen real horror stories. Sure, I’ve had a few emails and DMs about issues, but nothing catastrophic.
That said, as the Heat Geek cohort grows, I’ve noticed a problem with their guarantees. It all comes down to how you hire your installer. If you go through their platform, you get the guarantee. If you hire direct, you don’t, you’re on your own with no Heat Geek backing.
I published an article on this last night to make things clearer:
https://renewableheatinghub.co.uk/what-is-the-heat-geek-guarantee/
- 69 Online
Yes. They cost about £400 to buy or you might be able ...
By JamesPa , 17 minutes ago
If that's the case then you are right to be sceptical, ...
By JamesPa , 29 minutes ago
Havenwise App Help & Forum Support – Get the Most from Your Heat Pump
We’re pleased to announce that Havenwise are now joinin...
By Mars , 2 hours ago
By Lucia , 3 hours ago
By JamesPa , 4 hours ago
By jamespetts , 13 hours ago
By ASHP-BOBBA , 14 hours ago
By JamesPa , 15 hours ago
By Tim441 , 18 hours ago
By Transparent , 20 hours ago
By HCas , 23 hours ago
By jamespetts , 23 hours ago
By jamespetts , 24 hours ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 3 days ago
